Created on: 02/16/11 06:57 PM
RE: yikes
02/16/11 7:11 PM
Guy was lucky that wasn't a cop!
* Last updated by: DogoZX on 2/16/2011 @ 7:30 PM *
RE: yikes
02/17/11 10:40 AM
Yep...
* Last updated by: DogoZX on 2/17/2011 @ 10:40 AM *
RE: yikes
02/18/11 10:24 PM
Dog do you have that detector ?
It's on the way... gonna do my best to get it all mounted up on the zx14 in a configuration that is discrete and still works well... but if it doesn't work out, it will be going on my Mustang.
RE: yikes
02/19/11 11:22 AM
Does it come with ear piece ?
No, but it does have a port for an optional remote speaker. So hooking up an ear piece should be as simple as plugging one in.
RE: yikes
02/21/11 6:16 PM
My SRX showed today... there is actually a jack for a set of earphones located right in the back of the main display unit. That is in addition to the port for a optional remote amplified speaker (which it came with) located on the main control hub. The unit also came with a small remote LED warning light that can be mounted wherever and a small remote mute/volume control switch that also shuts off the laser shifters if tapped twice... THIS THING IS COOL!
RE: yikes
02/21/11 6:33 PM
Pics please
Of anything in particular?... or will thes do?
* Last updated by: DogoZX on 2/21/2011 @ 8:10 PM *
RE: yikes
02/22/11 5:24 PM
OMG
Lot of shit, huh? Don't need to use all of it though. Did a little mock up today and it looks promising. With some "massaging" the radar reciever and one laser should fit behind the gauge cluster, in the space between it and the windscreen. Another laser on the lower triple and one above the license plate. Head unit either on top or below the gauges and hub either under the seat or in battery compartment... done.
* Last updated by: DogoZX on 2/22/2011 @ 5:24 PM *
RE: yikes
02/22/11 6:53 PM
Lot of shit, huh?
Wireless ear piece would be sweet. Is it possible ? I saw one with a light that shines in your helmet on visor. I think the ear piece would be much better.
Did you take pics of your mock up ?
Also wondering about your stacks, installed ? Did you get the short race stacks,,,so many questions
RE: yikes
02/22/11 8:02 PM
Yeah, that's the HARD system from Legal Speeding...
I don't think it would be a simple plug 'n' play with the system I bought. It plugs inline with the detectors power source. My SRX's power source is hard wired, inside of the contol hub. Might be able to run it inline with the radar reciever. It uses the same, phone style plugs... but I'm thinkin' then it wouldn't alert laser.
As far as using a wireless earpiece, one of these, http://www.compnation.com/p-1499771-miccus-blubridge-mini-jack-music-transmitter-bluetooth-bluetooth-20.aspx?adtype=pla&kw={keyword}, and you'd be golden.
Sorry. I did not.
Stacks??? I don't have a clue what you are talking about ...
You know what's sad??? I have another set on the way.
Actually, I'm not gonna use the 15mm's for a bit... PM me.
RE: yikes
02/23/11 8:16 AM
The first set, two tall and two short,,,, Thought that was for CBR ?. Did you try that set up on the 14 ?
The first set is for my 10r. I have another set of those on the way... 'cuz I wanna try runnin' all shorts on that bike.
I figure at some point, I'll try running mixed stacks on my zx14... might as well if I have 'em... but I'm gonna run all 25mm's first... If you wanna try out the 15mm's, I'll send 'em to ya. I ended up getting Cutback's PC5, already sold my PC3, and my ignition module for the PC3 is for sale. Now, I don't plan on running the 15mm's until DJ releases the ignition module for the PC5.
* Last updated by: DogoZX on 2/23/2011 @ 8:44 AM *
RE: yikes
02/23/11 9:44 PM
SB6... that looks like a cool piggy... My DIS-4, on my Mustang, just went tits up on me... so I'm a little pizzed at MSD at the moment.
You see this?... http://www.zxforums.com/forums/zx-14-forum/47507-zx14-reflash-now-available.html Someone finally cracked the code... but they want $900!!!
RE: yikes
02/24/11 11:13 AM
warranty ?
Warranty is expired. MSD will rebuild it for $100-$150, but I don't think I'm gonna bother. One of my best buddy's brother is a great hacker/tuner. He tuned the Shelby Super Car.
RE: yikes
03/01/11 12:09 PM
Still tryin' to figure out what happened to his turkey and cheese on whole wheat.
