Givi trunk and mounting plate.
4 "highway bar" pegs mounts hold a 1.25" 316 stainless tube to the bike.
I had the 316 stainless tubes honed out to make a slip fit over the 1" 304 stainless tubes which i then had bent at a 4.75" radius bend but not quite a full 180 degree bend.
The reason i did it this way is so that i can adjust the trunk where i want it. Over the passenger seat, behind the passenger seat if i have a passenger, or slide out leaving only 2 tubes under my subframe.
i am still going to do some trimming of a few ends and paint most of the stainless black except for the slip fit areas.
