Thread: ****Power Increase****
Created on: 01/02/11 08:25 AM
jbzx14
jbzx14's Gravatar
01/02/11 8:25 AM
I'm looking to increase the power on my 14 but not cost me an arm and leg in doing so. I have already put a PC-5 on and getting ready to buy Brock's 4 into 1 exhaust.
Please help me decied on something that is not going to waste my money and that is best for my 14.
Thank,
JB
RE: ****Power Increase****
01/02/11 3:00 PM
Basics are pipe, power commander, filter. Velocity Stacks if you want to relocate some hp.
Hard core = Heads, cams, pistons, big bore or turbo.
Don't forget Gearing. I know it's NOT "Power" but sure would be the best cheapest way to get a massive eye opener.
* Last updated by: Romans on 1/2/2011 @ 3:14 PM *
01/02/11 3:30 PM
Keep an eye on your oil level for peak performance. And no, not under or overfilled. Wink-Wink!
Can't get any cheaper than a quart of oil.
01/02/11 4:00 PM
BETWEEN the upper and lower level lines .I just had to .
I opted to replace my pulsar cover...just to be at peace.
* Last updated by: blue07 on 1/2/2011 @ 4:03 PM *
01/02/11 4:12 PM
I'll bite, not under and not over, hmmmm so your not talking parasitic loss in the crank case from proper oil levels. Ok, oil additive ? quart eh,,,, not 500mm. Alright I give, which one makes the most POWER, or was this a swing and a miss ? Do tell.
01/02/11 4:16 PM
Can't be what he is talking about can it ? Ok, hot or cold oil,,, here we go.
01/02/11 4:28 PM
Manual doesn't state hot or cold.Only that it's checked after sitting a while.Vertical.Perpendicular.Flat surface.Equal height front to back.Level.At the balance point.Anywhere from just at or below the upper line,and anywhere at or above the lower line.BETWEEN...not HALF-WAY.(which is fine as well) .
* Last updated by: blue07 on 1/2/2011 @ 4:35 PM *
01/02/11 4:38 PM
Jb was looking for a power increase. I think we just told him to check his oil. Now that's funny. Sorry. Proper air pressure helps too, Weeeee. Sorry lol
01/02/11 4:54 PM
HUB started it!
And for all those worried about metal particles in your oil....and I quote..."Not only do dirt and METAL PARTICLES collect in the oil,but the oil itself loses it's lubricative quality if used too long"....owner's manual...pg 112.
* Last updated by: blue07 on 1/2/2011 @ 5:08 PM *
01/02/11 6:05 PM
You get the AMA-FIM catch wind of disshit going on and my old lady tells me I think too much in the past I bark the race [cheat] and the 'if only.' Well, if only she could figure out this is for secretshit only! You all answered your own questions you go questioning me.
So yes, smarty pants, it's that simple. Not me looking weirdwaysingworldantechNOclue so do not blame me someone running the AMA or who knows? I'd sure as hell be pointing fingers at that sap pulling points being that clueless to pull points or is it hose? Again, why do I use that dill is to pull someone's proverbial. Dis is the underground an do not point fingers at me, I'm the whack. I calledit. It was lame then as it was lame when first I heard it from FIM or AMA was it? Like, there's a difference? Yanking breather is zip change.
The Bubble Under My CUP is to: Fill it-till it-Signs off those diminishing returns. DIS MOUNT from bike and when waiting at the register listening to the change clang in your trouserstart dancing!
* Last updated by: Hub on 1/2/2011 @ 6:17 PM *
jbzx14
jbzx14's Gravatar
01/02/11 6:15 PM
Fuck your not supposed to fill the oil all the way to the top??!! FUCK!!!!
Roman, let me know more about the gearing! I have the stock gearing in the front and the rear. What do you recommend?
JB
* Last updated by: jbzx14 on 1/2/2011 @ 6:18 PM *
01/02/11 6:24 PM
Calm down, JB. YOur baby is going to be finely tuned around here, plus you are going to be, squideefied of all you know about bikes you think you know. now Relax. You sound like KANE with the pink slips. Who said anything about exceeding window.
There is a window there. It says, "do not fill past" you read your manual first think is desquidefying oneself. You fill past window, who's fault is that you screaming hydraulic lock the crankcase.
01/02/11 6:27 PM
Hey, smarty pants... Yer UP.
01/02/11 6:30 PM
Hub I am really trying to get this one. So, what you are saying is to change your oil more often than not. Correct ?
You must admit your above thread could have gone many directions. I was thinking the Zero weight oil thing to make more HP may have been one direction you may have been going, but I know that's not your stick. So,,,,,, what are you really saying ? You like new oil ? slipp- E
Not just her, do tell secret
No one told me I swear(f_ckers),,,, spill please.
My brain starting to hurt. Tap Tap Tap that's me out
jbzx14
jbzx14's Gravatar
01/02/11 6:40 PM
Hub I'm just f-ing with you!! LOL You guys are to cool!!!
01/02/11 6:40 PM
Squids can be funny too. Love the wipe out at The End. Classic
* Last updated by: Romans on 1/2/2011 @ 6:47 PM *
01/02/11 7:24 PM
Beast =
Cheapest way is to go down one in the front, up two in the back this will give you the beloved 16F/43R and then get ready for a wake up call. New bike in a dozen different ways.
Or just up four in the back. 17F/45. This method requires a New longer chain.
It would be wise to take baby steps with this one and try -1 in the front first and then make your opinion. Lots of info all over this site on gearing. It's a really big subject and it's not for every one. More depends on what you want to do with Your bike. Lots of Fun that much is for sure.
Have Fun With Her, she loves it.
01/02/11 9:13 PM
... talking parasitic loss in the crank case from proper oil levels .... Fuck your not supposed to fill the oil all the way to the top??!! FUCK!!!!
SheeeeeeeeeYaaaaaah! You two sit'inn in the back window with Whoola skirts and bobble headed out of place here [in page], are we? Place bubble closer to the piston undersidesays watch the bouncing ball bubble her up some; [more] push is a closer bubble to push the piston back up being the least resistance in the opposite direction so the bubble pushes stronger we windmill the crank [more].
Ringing out it's poor little neck every time out sort of points the way something is not right. I needed to call 119; Huston, we have a problem! Shhhhhhhhhyiminnysay nothing!
01/03/11 5:59 AM
Lol, Hub I hate sitting in the back. At least your not making me do it with gum on my nose. Hated that shit, booo.
01/03/11 10:36 AM
I'm gumming my nose at the AMA for not getting it right. Points are politics and I've been there. So, every point counts. I cheated once and learned my lesson. Instead, I started to 360° other bikes for points so we were all even up on the same page. Well, as much as I could find externally [was enough] to send the gum on said pee know key-0-pointing the way.
tteksep
tteksep's Gravatar
Perth, Australia
01/04/11 10:34 AM
Hey Romans,
Thanks for the Vid. I just sold that model, same colours and everything, I think. What an ass! I'm now going to e-mail the link to the guy I sold it to. Should be good for a belly laugh.
Hahaha
Will try and dig up pic to show you.
* Last updated by: tteksep on 1/4/2011 @ 10:35 AM *
I'd rather have a bottle in front o' me than a frontal lobotomy!
tteksep
tteksep's Gravatar
Perth, Australia
01/04/11 10:41 AM
Romans, as promised, and no, any oil stains are not from the bike :-)
loadedmind
loadedmind's Gravatar
01/04/11 11:55 AM
jbzx14 - How is this bike used mainly? Is it mostly a commuter? Only for weekend twisties? Sport-touring? Is MPG a factor? What's already been said is pretty much given - gearing, tire pressure, PC, full exhaust to drop weight & improve HP, etc. Depending on money, believe it or not, wheels like BST's or Marchesini's will also make a definitive difference as the same amount of power now has to move something that weighs even less. Your own weight loss can also improve performance as well. Anything beyond this, you're looking at what Romans said - cams, pistons, big-bore kits, etc. and then the turbo kits. I've never ridden a turbo sportbike before, but I'd imagine MPG would suck in a major way and you'd really have to take it easy on the throttle so you don't fly off. ::8^)::
01/04/11 3:57 PM
Loaded don't say that, I missed the oil thingy LOL. Shhhhh.
01/04/11 4:06 PM
He might think your calling him a Squid. Should be fun.
