Thread: dyno tune results
Created on: 05/15/09 09:10 PM
b00fa
b00fa's Gravatar
Cambridge, Ontario
RE: dyno tune results
05/28/09 4:59 PM
[NOTE: The two posted dyno tune results that were at the top of this thread are now in the "Dyno Room" thread in this forum. They were moved there on 8/12/2009. -bg]
love that bike! and that wind screen great choices.
* Last updated by: bgordon on 8/12/2009 @ 2:19 PM *
I ride a 2008 ZX14 SE
PCV with Autotune
Vance & Hines slip ons
K&N air filter
Puig double bubble screen
GenMar Risers
Rizoma Grips
Throttle Miester
Engine Ice
Muzzy Fan
Muzzy Frame Sliders
APE Manual Cam Chain Tensioner
Spiegler brake & clutch lines
Carbone Laraine brake pads
Custom black anodized parts
MattTheHat
MattTheHat's Gravatar
06/17/09 6:04 PM
racertex,
My dyno results are scary close to yours. Like almost identical. Just got it back from the tuner this afternoon. Same mods, except I removed the flies and I'm running a BMC street filter.
I assume you're running the Yoshi without the sound level reducer?
-Matt
"If it has breasts or a motor, you're gonna have trouble with it."
Slowninja
06/17/09 7:37 PM
Didn't get a chart.. But 194 hp and 110 tq.
Stock made 158/98 or somethin like that.
Resident Drag Racing Expert.
ZX-16 in 2010
8.64 at 158 on motor
8.28 at 173 on nitrous
Back to stock for 2011.
9.24 @ 148
185 hp pump gas
ALUCARD
ALUCARD's Gravatar
06/18/09 1:37 PM
my o7' with the roaring toyz pipe & pc tuned by jamie at fuel moto in wisconsin made 172.09 hp & 103.14 lbs. of torque
racertex
racertex's Gravatar
06/18/09 4:47 PM
Hi Matt,
Yeah the Yoshi still has the restrictor - or whatever they call it- in it. I've thought about removing it for the cool sound, but I kinda like being able to quietly slip away down side streets after acting up! The air filter is stock. My results were probably a bit on the high side because I live near sea level, it was a particularly cool day and the relative humidity was low (compared to normal for around here) when it was on the dyno.
* Last updated by: racertex on 6/18/2009 @ 4:48 PM *
2008 ZX-14
Yoshi 4-1
PCIII w/custom map
Speedo Healer
croatzx14
croatzx14's Gravatar
06/20/09 12:10 PM
WFO motorsports dyno tuned to 170HP but running little rich because NOS.On spray 210HP.St Louis area,about 600ft elevation.
skjuzmyspeling
Gawn
Gawn's Gravatar
07/11/09 7:01 AM
Mine is all stock and made 170hp and 106 ft lbs torque. Slowninja I noticed your from OKC thats cool. What set up are you running?
10.30@141 So far :(
hoopie
07/12/09 10:27 AM
My post on my dyno is here http://www.zx14ninjaforums.com/messages.cfm?threadid=0E6E4852-1372-66AE-3B35460FF92B37DD
169.5 before 186.5 after with Full Yosh R77
2008 Kawasaki ZX14 Saphire Blue. Yosh R77 Full Titanium Exhaust, Power Commander 5, Custom Map, TRex Frame sliders, MRA Touring wind screen, Speed Tactics fender eliminator, Heli Bar Risers, Lawst cause frame plugs,Ketie Tank Pad
Slowninja
07/12/09 12:53 PM
Gawn Sez:
You from okc too??
i'm running a brocks pipe, no air filter, thin head gasket and cam gears. lowered stretched and strapped. MRX01 fuel (too high of an octane for n/a.. but i'm eventually going to spray the bike.. eventually)
ZX-16 in 2010
9.24 @ 148
185 hp pump gas
tteksep
tteksep's Gravatar
Perth, Australia
07/25/09 8:52 AM
Just had mine done today. Mods are... DNA Air Filter, PCIII, Secondary Butterflies removed. That's it. Stock cans.
Rear Wheel HP: 184.28
Max Torque: 112.46 ft/lbs
Done at Bunbury Dyno by Todd Patterson. An excellent job with great service. I'm happy. Can't post the chart as I don't have a scanner at home. Will try the Muzzy M10 later this year and see what improvements I get.
I'd rather have a bottle in front o' me than a frontal lobotomy!
laverda1200
Calgary, Alberta, Canada
07/26/09 3:40 PM
I ran my 08 ZX 14 SE yesterday, roughly 600 miles on the motor, unfortunately a really hot day, just over 100 F, rare for here in western Canada. We are at about 3,800 feet above seal level.
I ran the bike to get a stock baseline, and to check air/fuel ratio, only change so far is addition of a K & N air filter, just shopping for a pipe, and have confirmed a PC V with autotuner will work for the 08 even though Dyno Tec says only 09 and later, but am being told autotuner is out of stock until mid September.
See attached, 159.47 hp, 99.67 torque, and running substantially rich from about 4,000 rom and getting progressively richer all the way to red line. Looks like a fair bit of possible improvement available just with a little air/fuel ratio tweaking alone. Looking at the chart bg gordon posted, his bikes first run shows rich condition, then second run with mixture leaned out it looks like he picked up additional power/torque and possibly smoothness.
Paul
sorry, guys, I can't get the pdf file of the scanned dyno run to post, looks like the photo/pdf can't be picked up right off the home computer, does it have to be uploaded somewhere first? Help.
2008 Kawasaki ZX 14 SE, Power Commander V and Autotune, Manic Salamander bar ends, Cox Racing radiator screen, LSL frame sliders, GIVI V35 hard bags
07/26/09 9:11 PM
I got my PCV and Autotune for my 08 at Fuelmotousa.com about a month ago. Might want to try them. It looks pretty easy to install the PC. I really have to get that thing on there.
hoopie
07/27/09 7:50 AM
Try uploading to photobucket first then attach the image tag
harleyzx1400
harleyzx1400's Gravatar
Cape Town, South Africa
07/27/09 11:17 AM
My 07 with a filter and full Arata system showed 180.79 RWHP and 147.87 Nm of torque. After fitting a PC and dynotuning, the rwhp was 187.73 and 150.37 Nm of torque. This was done on a dynojet at sea level @ 31.66 degrees C, 1009.15 mbars and 33% humidity. I will try and post the results map.
b00fa
b00fa's Gravatar
Cambridge, Ontario
07/27/09 12:32 PM
why are my numbers so much lower than everyone elses i'm sure there is a reason but would like it to be explained
PCV with Autotune
K&N air filter
GenMar Risers
Rizoma Grips
Throttle Miester
Engine Ice
Muzzy Fan
Muzzy Frame Sliders
hoopie
07/27/09 2:59 PM
I wouldnt worry about the numbers as all dynos read different. the before and afters is what you are looking for. It looks like you have a flat spot from 8 to 9k
Slowninja
07/27/09 4:50 PM
precisely.
some dyno's are tight, some are loose. You may have gotten on a tight one. Don't worry about it, just worry about the gains
ZX-16 in 2010
9.24 @ 148
185 hp pump gas
Gawn
Gawn's Gravatar
07/27/09 8:36 PM
Hey Slowninja I'm from MWC. Lets try to meet up at Thursday night at Hooters on the the south side.
10.30@141 So far :(
Slowninja
07/27/09 8:48 PM
Haha... Sorry don't mean to laugh.. Thats not going to happen, and theres a story that goes along with it.. But the moral of the story is i'm not going back to that bike night lol
ZX-16 in 2010
9.24 @ 148
185 hp pump gas
Gawn
Gawn's Gravatar
07/29/09 7:37 PM
Hey Slow where did you take your bike when you got it tuned? Or who did the tune? I'm assuming they had an in house Dyno.
10.30@141 So far :(
Slowninja
07/29/09 9:44 PM
I took it to Brady at Metric cycles. Really good tuner and really cool guy. There's another guy that does em, but he does it on the side and you have to leave your bike for a day. BUT, he'll do actual real world tuning and data aquisition. I have no personal experience with him, just what he's told me.. But Brady is pretty good for the $$ lol
ZX-16 in 2010
9.24 @ 148
185 hp pump gas
Philhnnss
Philhnnss's Gravatar
Lost In Oklahoma
07/30/09 1:28 AM
Timber got his tuned at Phil's Cycle in El Reno. He was happy, and it's a lot closer than Tulsa.
2006 ZX-14
1984 ZX750E1
07/30/09 6:12 AM
<<< Holds crotch and now laughs. STOCK CANS!
Gonna pound you Linears with that aftermarketshit
* Last updated by: Hub on 7/30/2009 @ 6:14 AM *
TaintedTattoo
TaintedTattoo's Gravatar
08/04/09 11:18 AM
Looks like I am in the ballpark,, ran for the first time last week 187HP exactly, with a Brocks gen 111 and pc3, stock filter, street map. Right after I got off an '08 Busa ran 188HP with a full Yoshi system on.
tteksep
tteksep's Gravatar
Perth, Australia
08/08/09 11:45 PM
Hub,
I'm lost. Whadya mean "Gonna pound you Linears with that aftermarketshit"??
Stock exhausts and after doing an Iron Butt run of 1600kms in 24 hours, I gotta say this thing purrs. 3400kms in 3.5 days and it didn't miss a beat PLUS it ran better than it has ever run before. I'll be taking it down the drags in Sept when our season starts but I suspect I'll only get one run in before I get kicked off (until I get an ANDRA license). Once we run under 10 seconds, they kick us off if we don't have a full ANDRA license.
