Thread: APE manual CCT
Created on: 01/19/13 11:58 AM
APE manual CCT
01/19/13 11:58 AM
Just installed one. Gotta get the valve cover back on and everything buttoned up before I can fire it up and give a listen. Anyone else using one?
RE: APE manual CCT
01/19/13 3:01 PM
yep
RE: APE manual CCT
01/19/13 4:22 PM
It's on my list. I should have bought it from Privateer last year!
zxrider11
RE: APE manual CCT
01/20/13 5:55 AM
Got mine from Schnitz, no more start up rattle.
http://store.schnitzracing.com/categories/kawasaki/ninja-zx14/engine/camshafts-tensioners.html
2008 ZX14
2012 KTM 690 Enduro R
RE: APE manual CCT
01/20/13 3:05 PM
Finished putting it back together today (all but the plastics) and fired it up. Sounded a little rattly static adjusted according to directions, so I turned it in a bit and it went quiet.
RE: APE manual CCT
01/20/13 6:09 PM
Awesome! I will be putting mine in early spring.
tbolt
tbolt's Gravatar
RE: APE manual CCT
01/21/13 7:58 AM
Wouldn't it been cheaper and easier to have turned down your hearing aide so you didn't hear the rattle?!?!
RE: APE manual CCT
01/21/13 10:55 AM
Your motors will thank you!
ErikR
RE: APE manual CCT
01/21/13 12:52 PM
The APE manual CCT is on my list of things to do this spring.
RE: APE manual CCT
01/21/13 1:37 PM
What? Speak up! Try using the caps lock and maybe bigger font!
P.S. Mine wasn't rattling. Yet.
* Last updated by: Danno on 1/21/2013 @ 1:38 PM *
RE: APE manual CCT
01/21/13 3:25 PM
I'm actually looking for a ZX-12 modified CCT. How often does one have to adjust the Ape?
smokinstorm
smokinstorm's Gravatar
RE: APE manual CCT
01/21/13 5:37 PM
It's in the NA14. It almost sounds too good to be true not listening to those damned marbles at startup.
2009 Monster Edition ZX14, 70" wheelbase, 16-46 gearing, air shifter, Shinko Drag Radial. 2005 Turbo Hayabusa, 74" wheelbase, 16-43 gearing, foot shifted, Shinko Drag Radial. 2001 GSXR 1000, long, low and not stock.
RE: APE manual CCT
01/21/13 6:07 PM
If it starts getting rattly, you unlock the stop nut and twist it in a couple of turns until it quiets down again. takes about 10 seconds. I doubt if you have to touch it more than once a year, but I'll find out for sure over time. You have to pull it every time you adjust valve clearances anyway, but it's a lot easier than what you have to do to re-set the stocker. I think the issue with some (but not all) stock CCTs is they lose their hydraulic prime when the bike sits overnight and it takes a bit of oil circulation to get them working as designed again.
zxrider11
RE: APE manual CCT
01/21/13 6:14 PM
I got tired of explaining to all my Suzuki riding buddies that the start-up rattle was completely normal.
My bike had 30,000 miles when I finally spent $50 for the APE and installed it.
2008 ZX14
RE: APE manual CCT
01/22/13 12:02 AM
It's likely not a serious issue, especially if you let it idle until it stops, it's just annoying. Makes an otherwise fine machine sound like a shitpile.
P.S. Don't forget to swap or replace the tensioner o-ring. There's no gasket.
* Last updated by: Danno on 1/22/2013 @ 12:05 AM *
RE: APE manual CCT
01/22/13 10:01 AM
Form what I heard in the past, it really doesn't seem to require adjusting. Some had it on for a couple years without touching it. I think I recall someone saying he adjusted it one time.
RE: APE manual CCT
01/22/13 11:23 AM
I sold my Carter modified ZX12 CCT last year to someone on this forum, lol I forget who.
I was lucky to get one, frankly. Carter really only makes them for the engines they build. But every engine they build gets one.
And yes, you bolt it in, adjust the preload bolt, and you are done. From then on, oil pressure is all you need to keep it adjusted right.
The only reason I sold mine, which I purchased for my 2008 ZX14, was because I traded the ZX14 in before I had a chance to install it. Since I was riding so much on trips to rallys and such.
I know the guy that purchased it PMed me and told me his engine got really quiet, which is what is expected.
* Last updated by: privateer on 1/22/2013 @ 11:24 AM *
RE: APE manual CCT
01/22/13 12:40 PM
Is there any advantage to the modded 12R tensioner compared to the APE? APE tensioners are readily available in the $50+or- range.
RE: APE manual CCT
01/22/13 5:55 PM
Modded 12R auto adjusts. APE is manual & Much cheaper.
RE: APE manual CCT
01/22/13 6:33 PM
I'm not convinced auto-adjustment is an advantage when the adjustment of the APE is so quick and simple. To me, the more idiot-proof things are, the easier it is for idiots to get involved.
* Last updated by: Danno on 1/22/2013 @ 6:33 PM *
RE: APE manual CCT
01/23/13 3:00 AM
I know, right? Since Carter puts the 12R modded CCT in all his high performance (drag) engines, I guess he is an idiot.
RE: APE manual CCT
01/23/13 9:19 AM
I can't believe it but the APE is .2 oz heavier than the OEM CCT and I would assume heavier than the modded 12r CCT. It's a small dif like but for something that was made simpler, you'd think they could easily make it lighter.
RE: APE manual CCT
01/23/13 11:42 AM
The unit really isn't complicated...you could actually make your own...following their build.The bolt anyway...could be lighter....
RE: APE manual CCT
01/24/13 4:36 AM
I wouldn't know. Never heard of him or his engines. Race parts don't always work well in street use. If his modded CCTs are all that great, he should be blowing APE out of the water selling them. Sounds like something a racer would come up with when there's no cheaper alternative. What do they sell for? What's the modification? How is is better than stock? How well do they work over the long haul? You saying they're great and then getting sarcastic when someone asks for facts is meaningless.
RE: APE manual CCT
01/24/13 4:42 AM
Who is Carter ????
Carpenter ??? I think this is maybe who you mean ?
He's also selling Joe Gibbs Racing Oil. Got to get me some of that.
Nothing on the site about modified camchain tensioners except as a part of the race packages. Guess you have to know someone who races and wait until their motor blows up to get one. Or you could buy the race package, throw the rest away and then you'd have a fancy CCT.
* Last updated by: Danno on 1/24/2013 @ 4:48 AM *
