I like the new Muzzy's so much better then stock in terms of sound and weight reduction so they are definitely not coming off.
Kidii02, I too started off with the Muzzy slip-ons.(love Em) Then went nuts trying to fix that pop or Stop the back fire that you get on de cell at 3800RPM. I too was thinking buy a power commander get a good map and this would fix my problem. Nope.
As you read above from the guys here, there is No fixing the pop completely with out a TRE006A. I tried all the tricks listed and made over hundred maps, changing one # at a time. It became a obsession. I had read that others were fixing the pop with Map changes and tune block off plates pair systems but I could NEVER do it. This drove me nuts. Rich lean you name it I tried it all. No could do.
Now after all that time and money TRE-006A now sleeps in my bike. All fixed. No pop, No backfire or gas explosions in my new pipes. All is as it should except N0 Gear Display(-)is what shows. The I've had it in and out playing. In is better for me. I hope this helps in some way.
Try it. What's 50 bucks if you look at what we spend on these toys. If you don't like it unplug it ?
Also there are different TREs so pick the wright one.
![](http://www.zx14ninjaforum.com/userfiles/romans/Copy of Muzzy Pipe 003.jpg)
I still sometime think today if it were not for that Back Fire or Pop May bike would have stayed with Muzzy Pipes and flies out with the TRE as it's Hot set up. Learned lots along the way
* Last updated by: Romans on 4/17/2011 @ 5:24 AM *
