Here is a link to my old thread from a year ago.
It went astray for a few pages so I thought I'd start this one now that I am ready to get these babies on the 14. There has been a few little projects related to the install and I am in the process of finishing those off before Spring. I'll post everything here on this thread (provided it does not go too far astray--LOL).
Sprocket Studs
The latest is the sprocket. I painted it orange and got aluminum nuts for it. The AFAM sprocket fits fine but there is something weird about the sprocket studs on the Carro. It comes with M10 x 1.25 thread nuts which seem to thread on the studs quite stiffly. Not quite binding, but not even close to smoothly turning on the threads. I could NOT spin these on too far with my fingers. I'd need a wrench. CZ tech said that the studs are made of very hard steel. That may be so but seems to me they should still thread smooth enough to draw the nuts up by hand.
The Pro-Bolt Sprocket nuts I got for the CZ rim were so hard to start on the threads of the sprocket studs that I decided it better to not use them. Pro-Bolt sprocket nuts are high quality and they easily thread on a 1.25 pitch bolt. They will not even start on the CZ sprocket studs. I forced one just a bit and discovered some tiny steel flakes that were sheared off of something. I ordered Driven Sprocket nuts which are all aluminum but I do not know if I can use those with the CZ rim because the CZ torque spec is 70 - 80 ft lbs which is too much for aluminum threads. That torque may be required for proper functioning of the CZ cush drive or some other aspect of performance. I'm waiting to hear from CZ Tech help. They have been very good about giving advise and info about their product.
Here is my problem, the Pro-Bolt sprocket nuts have a helicoil insert made of steel so that they will withstand high torque. As you can see, the steel threads have a sharp step that will not easily start into the threads on the CZ stud. I will be attempting to dremmel the step smooth. That was what was suggested by the CZ tech and it might solve the problem.
CZ nut and ProBolt nut
Aluminum Pro-Bolt nut with steel heli-coil insert
Here's a pic of the sprocket and wheel. I'l post pics and explain the painting process after this nut deal is tackled. Also, i have been doing some very delicate dremmeling to make Bridgeport valve stems seal properly on these rims and I'll post an explanation of that or an admonishment based on how successful I am in getting that to work. Think it will be fine.
CZ rim with painted AFAM sprocket and anodized gold sprocket nuts (that I dare not thread on).
* Last updated by: Rook on 2/13/2013 @ 2:51 PM *
