This is why pulling the flies does not increase HP or Torque, but only gives you access to what you already have more quickly.
home, read Priv's slow, read it quick. No matter how slow or fast you read it, it is still saying the same thing, right?
I still don't think I got what I was looking for though.
That's why. You can't solve it with 'more air.' The rest does not make sense. So either you are right or the other person is wrong. One says same air only faster is the move into the chamber, and you are saying there is more air entering the chamber. So, now explain yourself so you have your side as the 'more air camp.'
Pulling the flies delivers much more air in the lower rpms where the flies would have been closed. This obviously leans out the air/fuel ratio at those rpms.
I am going to follow each rpm and see if that is true. So, sustained, did we lean out the engine with both throttles plates running at the same steady mph? Wasn't that the same air entering? Wasn't the same air entering, but since there is less air, more gas, the beauty of open loop acting like a carb going up a mountain.
What was pulled out of that carb jet @ the penultimate number was more air/less air? Smoke and chug up the hilless air? Same amount went in, just less of it are the molecules distances. So with that kind of same gas entering, we didn't make the jet holes bigger, did we? We turn the carb upside down at sea level or rocky mountain high, won't they pour out the same we take a solid now, turn the sand timer in the hour glass. We see the same amount coming out yet?
So who went in faster? Who went in with 'more what?'
In the 06, 07 models it did cause a lean condition at 3800RPM. Newer models had faster fly opening so the condition was not as severe.
When you remove the fliesubsay, did this lean out the bike? If a sub closes, it creates a vacuum. You snap the throttle closed, you richen on lift. Same vacuum created [almost] is that modulation on the intake air sensor you throttle up.
If you have an AFR meter, watch lift, watch WOT, they both run fat under heavy loads. Only one theory is right/correct/absofuckinglootly ass eye shitan breathe same air is the penultimate numberubbing it in your face. I'm just the messenger walking thru the shit I've been reading no matter wear out my welcome I go.
MORE AIR MY ASS!
