I don't see where I would need to use any 2.3mm steels moving forward with this project.
Remember I said the factory installed a book setting is the pack? They are not about to send out a less than factory posted book spec, right? The frictions are a given so when the physical stack happens, she dials back into the factory number. That's the original steels pointing that out is my take on the numbers it was packed with to meet spec not be under spec QC (quality controlled blueprinting formula).
The old/stock clutch I pulled out had 2 of the suckers and they were the most burned up. They also contributed to the stack height being under spec (in addition to the worn frictions).
Notice the spec is gone with the wear of the steels/frictions. If no wear, right back to 54.2.
53.52 - 54.5 is 1st gen. Look at 54.2 is the gen2; in the middle of the max 54.5 or just about. It says both gens use the same clutch plates, both can be dialed in 54.5 at the max number. Leave my 54.9 out of it for now.
Also, if I already have all new frictions and steels coming, why would I want to mix the old 'seasoned' plates with my new ones?
Lettuce go racing. How much lettuce are we throwing at the hobby? A pro racing budge goes like; toss the worn pack and throw in fresh for the next round, final round, etc. Hobbyist has what kind of budge? Say in the cheap seats. So your spares... If something starts slipping by the time the mile comes and you warmed up on the new pack at the strip. All of a sudden if you only could set the pack back tighter with more meat. Where on a sunday do you find a dealer open you now have a slipping clutch. Do I buy spare new and bring it or am I thinking I turn around and go home, if only I had a spare... any spare I would have finished in the money. Understand the spares mentality to racing? The budget constraint? The loophole? Like spare sprockets for the track. More parts to bring just in case race.
I'm telling Bradley from experience that these bikes NEED the judder spring under HEAVY acceleration. I know who he will listen to.
Took me manpill I go racing. Took me wiring up a foot kill switch. Took me one squeak out the basket was one release and who knows if I can stay out of that harmonic on the collapse and no noise... the rest is WOT @ no lift of throttle pipe, no pull of clutch lever, no judder mutters a word up is wink-wink LOL.
A clutch stack at maximum recommended height, which I should have using all 2.6mm steels, will allow the clutch to engage with the lever juuuust off the handlebar grip like Mav said.
I made my post correction about where we break clutch plate. Mav may have it reversed. You need to grasp the theory, you are walking it in the reverse. Think about this. When the clutch cable needed to be adjusted at the thumb wheel, we were losing clutch stack and the cable had to be brought away from the grip or we could not extend the rod to have full throw at the perch to grip, remember those days? That was not cable stretch. Like the bridge sags the cables stretched is BS = Clutch wear... Period!
The foot takes out the return spring tension. The stack is so far out there, one tiny yank at the lever breaks the plates is right there. Stack moves into the engine, I pull more lever to break plates, right? So I'm at the light and I'm this side of slapping dogs into the gear next to it, she is waiting. The hand has yet to pull the clutch lever. As soon as that light turns fandango, the lever hardly pulls in, breaks the plates, the gear plops in, the lever is back outhell is sneak up on you motherfuckers if I was only racing and prepping the bike for it.
When you say you have the adjustment all the way in, are you referring to the little wheel on the clutch lever that sets the distance to the bar for comfortable use
Right, the pack is so far out, the lever can be kissing the grip it's going to break loose just like that. We see the stack to sinking into the engine side yet? Keep thinking it out.
Get a lane! I swallowed me manpill and it put me foot to sleep. I'll eat your setups for breakfast of chump pee yawns. Nice clutch pack'inn switchew guys.
