Kruz, It's just the grease that 's weighing me down now. Once all that heavy white litheum flings outa there, I'll be weighing in at an ounce or 2 lighter. I'll be able to fly!
Them flies and stuff...gotta go baby!
Where have we heard that before?
"Driving the pins through that outer plate"....You DID grind the mushroomed heads off FIRST(the factory heads),didn't you? With those off,you should be able to virtually slide the link straight out.And as far as crimping them...it's a VERY SMALL mushroom effect.NOT anything like the factory rivet deal.Shouldn't need but a small bit of turning with the tool to get the correct mushroom.
"After seeing the amount of force required to drive those pins through the outer plate, I am confident they will never come out. After all, they are riveted on the outside and fit tight as heck in the plate holes."
.......I meant that it took quite a bit of force to push the pins through the outer plate on the connecting link. The pins slid throught the inner links easy but the outer holes were so tight , I dare say I might ride without riveting the pin heads if I had to. ....but I don't have to
I did grind the pin heads when I cut the old chain and then again to chop down the new one.
![](http://www.zx14ninjaforum.com/userfiles/Rook/rivet.head.ground.JPG)
Even with pins ground off, I was cranking on that ratchet to push the pins through the outer plates.
There's a little "ring" embedded in the link pins,right where you mushroom it.Supposed to just barely mushroom to or above those rings for a good smooth operating link.You have that sweet little spacer....so yours should be really simple to mushroom to the correct amount.
The ZZZ came with a gauge to check the diam of the mushroomed (riveted) head. The rivet fits in the circle part of the gauge ...........
![](http://i461.photobucket.com/albums/qq335/Rookzx/2008%20ZX-14/Drive%20Chain/31rivotcheckdone.jpg)
..........but if the rivet is small enough diam to slide through the straight part, it needs to be squashed bigger.
![](http://i461.photobucket.com/albums/qq335/Rookzx/2008%20ZX-14/Drive%20Chain/31rivotcheckunfinished.jpg)
The spacers fit between middle and outer plates and rest on top of the x-rings. The spacers will maintain the proper inner play regardless of how tight you squeeze the rivet heads. They pulled out pretty easily after I finished the riveting the pin heads. This shot was before I riveted the heads.
![](http://i461.photobucket.com/albums/qq335/Rookzx/2008%20ZX-14/Drive%20Chain/28pinsthroughplate.jpg)
* Last updated by: Rook on 3/2/2011 @ 5:13 PM *
