Thread: Brock's lowering straps question
Created on: 08/02/15 06:19 PM
skewedTotheLeft
08/02/15 6:19 PM
I just bought a Brock's front-end lowering kit and as some of you know I have the Scott's steering damper on my bike. In other forums some people say that you have to run the straps over the lower triple tree and others say that you can use the upper triple tree with the Brock's straps and the Scott's stabilizer.
If they will work on the lower triple tree, that seems like the best option to me--that way it should not interfere with the Scott's damper, right?
Any feedback will be appreciated.
Thanks,
BostonBob
RE: Brock's lowering straps question
09/09/15 6:38 AM
I have the same setup on my 2013 ZX14R.
The strap is run over the steering head as it is designed to do.
The strap needs to fold in half as it goes around and over neck.
Works perfectly, relaxed or in tension.
