1. What is there to be gained if anything: A reduction in friction. Rubber squeezes into plate is the only difference. Same tensile strength is a 530 size so you chase a minimum of strength as factory.
2. For Racing: Pin length has to compensate for the rubber o-rings. For racing, the other chain becomes lighter with shorter pins and no o-rings.
3. Anybody have some solid facts? My research would be: if I had a new chain with o-ring, I'd get out my bread making 'ounce scale' for salts, baking powder, other spoon size weights; move the scale under a few links and begin to push up on the o-ring links. Swap chains and push the one link that will move or whatever links move, they are going to show a frictional difference. That's about as scientific as who makes less ounces of push to move a link from a stationary link.
* Last updated by: Hub on 1/16/2015 @ 7:11 PM *
