Thread: reasonably priced seat
Created on: 10/07/10 12:47 PM
rich67
10/07/10 12:47 PM
Probably been asked before, But who makes a reasonably priced, comfortable seat??
06 red zed
loadedmind
loadedmind's Gravatar
RE: reasonably priced seat
10/07/10 3:06 PM
rich67, what ErikR said, really. I was lucky enough to find one that the guy took off immediately after he bought his Concours so mine was unused. If you go this route, you need to find a C14 or Concours 14 seat because the other one won't work. Basically, all that's needed is replace the two brackets under the Connie with the ones from the stock seat and you're good to go. I paid $200 for mine. I can't say enough good things about this seat. Check http://forums.concours.org from time to time. Or, you can register at their site and sign up for the RSS feeds so you know when someone posts something for sale in that section.
The only thing I can add is that you might consider other things such as an Airhawk seat cushion, sheepskin, etc. Basically, the Airhawk is a rubber seat with air pockets. You can buy them in different shapes and sizes. You blow it up to the comfort level you want. It's best to experiment. They have hooks fore and aft to connect under the seat to keep it from moving, but mine still moves a bit. Also, you don't want to mess with this one if you're going to be going through a lot of corners because of how much extra movement created by the cushion. It's really meant for the cross country trips where it's mostly highway. You can always deflate it and stick it in a saddlebag if you want to hit the twisties.
The best combination I've found is make sure you wear some cycle shorts, like spandex, underneath, liberally apply some powder (I use Anti Monkey Butt) and then address the seat. There's lots and lots of discussions over at sport-touring.net regarding recommendations for long haul setups.
* Last updated by: loadedmind on 10/7/2010 @ 3:09 PM *
ninjamaster
ninjamaster's Gravatar
10/07/10 10:10 PM
O.k. I have to ask about the Monkey butt.Does it work?Does baby powder do the same thing.I agree with the heatmaking things uncomfortable with any seat.I got some as a gag gift a couple years ago and keep forgeting about it.Need some input!!!
Green means GO!!!!!!!!!!!!
2006 ZX14
2004 ZX10R
2009 ZX6R Monster
1994 ZX7
1987 Yamaha YSR50
2003 ZX6RR
1986 Ducati 750 F1A
2008 KLR 650
1993 ZX11
2011 Concours 14
2009 Aprilia RS125
hoopie
10/08/10 11:37 AM
Monkey butt powder rules! as a dirt bike rider I use it often. Even better is motorcylce under. I have a pair made by Fox with padding on it that helps alot on dirt bikes.
2008 Kawasaki ZX14 Saphire Blue. Yosh R77 Full Titanium Exhaust, Power Commander 5, Custom Map, TRex Frame sliders, MRA Touring wind screen, Speed Tactics fender eliminator, Heli Bar Risers, Lawst cause frame plugs,Ketie Tank Pad
rich67
10/08/10 11:51 AM
Thanks guys for all your replies...
06 red zed
loadedmind
10/08/10 1:11 PM
Personally, I'm not fond of the smell of baby powder, so that's my first issue. Second, it seems like the monkey butt stuff just works better. It hangs out longer and seems to be a bit thicker.
