Thread: Heat Insulator Rubber Shield, Engine
Created on: 12/30/11 01:05 PM
12/30/11 1:05 PM
Heat Insulator Rubber Plate Removal, Engine-Gen1
The heat insulator plate over the motor is opened up on top or removed completely in order to to remove the cylinder head cover. There is not much else reason to remove it except to make the engine more accessible or to reduce overall weight of the bike.
Some have suggested that the heat insulator plate is designed to maintain lower temperature air in the the air box. If this is true, permanently removing the heat insulator plate may actually decrease engine performance. If this is so, it would probably be a factor at low speed more than it would at high speed. Many race bikes are run without heat insulator plates on the motor. The heat insulator plate over the top of the air box is also commonly removed.
Do First:
Remove Stick Coil Subharness, Steps 1 through 3.
Remove Engine Subharness, Steps 1 through 4.
Remove Camshaft Sensor Lead, Steps 1 through 3.
Remove Clean air switch valve, steps 1-7
Remove Throttle Body Assembly, steps 1-9
Remove Heat Shield Wings bolts and push pins, steps 3 and 4.
Disconnect the lower end of the Crankcase Breather Vent Pipe (see Crankcase Breather Vent Pipe, step 2).
Removal
1. Unfasten the tab [D] on both sides of the mat.
2. The front of the heat insulator plate turns up. Lift the radiator overflow hose and pull the heat insulator plate toward the back of the engine compartment.
3. Pull the front of the insulator mat backward while maneuvering it over the objects such as stick coils and throttle body holders.
Pull the back of the blanket forward.
Remove the insulator blanket.
Installation
4. Reverse steps 1 through 3 to install the heat insulator shield.
Install Heat Shield Wings bolts and push pins, steps 3 and 4.
Install Throttle Body Assembly, steps 19 through 33. http://zx14ninjaforum.com/messages.cfm?threadid=62F83816-D56B-84E2-14E2834C9FFA4D60
Install Clean air switch valve, steps 1 through 7, reverse procedure
Install Camshaft Sensor Lead, Steps 5 through 8.
Install Engine Subharness., Step 5.
Install Stick Coil Subharness, Steps 4 and 5.
Connect the lower end of the Crankcase Breather Vent Pipe (see Crankcase Breather Vent Pipe, step 3).
Weight
* Last updated by: Rook on 1/5/2018 @ 6:01 PM *
RE: Heat Insulator Rubber Shield, Engine
12/30/11 1:52 PM
Although I might myself be more inclined to think the insulator blanket is there to regulate the temp on the underside of fuel tank?IDK
GREAT how-to's Rook...very professional my man!You really might want to consider going full time with these types of posts.For a company with big bucks.You could easily fit right in.
* Last updated by: Grn14 on 12/30/2011 @ 1:54 PM *
12/30/11 2:13 PM
Thanks, Grn. Sure would be nice but for now, I'll keep my day job. If you hear of any oppennings, let me know!
Jyppendaal
05/25/13 4:56 AM
Does anyone know, has this rubber shield remained the same shape between 2006-2011 ? Did kawasaki cut it smaller for 2010 ? Just wondering why my friends 2010 does not have this on the valve cover, instead the rubber shield covers engine only from the throttle bodies and downwards there. Maybe someone has cut this for easier and better access ?
05/26/13 5:29 PM
Or ripped it getting it out and ended up trimming it down.
05/26/13 6:11 PM
Sounds like somebody did a chop job. Personally, I would just finish it since the rubber mat is no longer whole anyway. Cut it off.
04/26/17 2:56 PM
updated
01/05/18 5:46 PM
done
