Thread: exhaust leak
Created on: 09/07/09 07:03 PM
mre14
mre14's Gravatar
exhaust leak
09/07/09 7:03 PM
So I am in the process of installing....well i have already installed and removed the Muzzy m14/10 system but seems the 1st header on the right hand side has a leak!!! i have tighten this thing as much as I can!!!
WHATS THE PROBLEM????
I did not purchase new gaskets as I was told I wouldn't need them because I have yet to reach 1k miles though I am really close!!!!
Is there a specific pattern to putting these things on??? please let me know as I was going to order new gaskets in the morning but if I don't have to and all I need to do is change my install technique I would rather do that?!?!?!
Thank you!!!
1995 ZX-9 custom paint; 2008 ZX-14 Atomic Silver 2018 ZX-14 Grey Black Orange you glad I didn't say yellow
Sharkey
Sharkey's Gravatar
Grass Valley, CA
RE: exhaust leak
09/07/09 8:11 PM
It's alwaysw good to put on new gaskets. But the nuts only torque to25 ftlbs! If you have tightened them much beyond that it probably flattened the copper rings (gaskets) beyond proper function.
Also look where the headder and midpipe join. If you see any little V shaped caarbon deposit, it is pointing to a leak.
My Muzzy slip ons use the stock gasket to join to the headder. I would replace that too if you have one. The clamp bolts get tightened to 13 ftlbs.
I can't ever find these common parts at the dealership. I usually order on line. UPS is the new snail mail!
Good luck
Sharkey
* Last updated by: Sharkey on 9/7/2009 @ 8:12 PM *
Removed GPS.
RE: exhaust leak
09/07/09 11:26 PM
Turn a paper cup upside down and smash it with your foot. OHoooooooK, lets go get a cup of cough eee. The hell happened to yer sipper? That thing is gonna leak, no?
Sharkey says: It's always good to put on new gaskets.
1+
Bingo! Weep Halfista Vinner!
buck20
buck20's Gravatar
RE: exhaust leak
09/08/09 12:23 AM
I put in new gaskets but still had leaks till I used some high temp copper sealant at all joints, just a little is all it takes.. No more leaks!
To much to list!
b00fa
b00fa's Gravatar
Cambridge, Ontario
RE: exhaust leak
09/08/09 10:47 AM
proper torque on the head bolts is important if you over torque you can break the bolts of the head and always use new gaskets. I put a little bit of grease on each gasket to hold it in place in the head while you place the header into position, just makes life easier.
I ride a 2008 ZX14 SE
PCV with Autotune
Vance & Hines slip ons
K&N air filter
Puig double bubble screen
GenMar Risers
Rizoma Grips
Throttle Miester
Engine Ice
Muzzy Fan
Muzzy Frame Sliders
APE Manual Cam Chain Tensioner
Spiegler brake & clutch lines
Carbone Laraine brake pads
Custom black anodized parts
Slowninja
RE: exhaust leak
09/08/09 8:51 PM
lets not forget, you can also bend the flanges on the header.
new gaskets should take care of it. Although, i am still using the stock (13k mile) gaskets on mine.. Had the whole system off 7-8 times..
Resident Drag Racing Expert.
ZX-16 in 2010
8.64 at 158 on motor
8.28 at 173 on nitrous
Back to stock for 2011.
9.24 @ 148
185 hp pump gas
Sharkey
Sharkey's Gravatar
Grass Valley, CA
RE: exhaust leak
09/09/09 6:39 PM
If the nuts were overtorqued the copper ring gaskets would be compressed more than if tightened to normal torque. So If you back the nuts off to get back to proper torque, after overtightening, the gaskets would not have a truly tight seal, they'd be too squished.
I squeezed the copper rings with my thumb and forefinger to make them ever slightly out of round. That caused just enough binding when put in the block to hold them in until I got the headder up there.
I always use new gaskets because I want the assurity that I woln't have to disassemble the item again on that account! I'm lazy.
Sharkey
Removed GPS.
mre14
mre14's Gravatar
RE: exhaust leak
09/09/09 8:04 PM
Hey everyone thanks for all the info!!
I ordered the rings from Schnitz yesterday with 1 day shipping!!! they arrived this morning just after 10am, I went and bought the copper sealent, and a torque wrench!!! took the radiator off that way I could easily get to the bolts and put her all back together!!!
started her up and she sounds perfect no more air rushing sound!!!!
Thanks again!!!
@slowninja didn't know those flanges could be bent!!! can they be unbent??? what happens if they are bent???
Slowninja
RE: exhaust leak
09/12/09 9:15 PM
I'm not sayin i've seen them bent, just that they could be if they were way overtorqued.
ZX-16 in 2010
9.24 @ 148
185 hp pump gas
RE: exhaust leak
11/03/09 8:31 PM
Copper sealant sounds like a great idea for sealing the joints in the pipes. Only problem is the Tsukigi system fit so tight, I could barely get the pipes together without sticky sealant. I actually had to assemble the header through the collector before bolting the thing on. There was no way I was going to get those pipes slid together hanging under the bike.
