The hag trick of a jack under the swing got me thinking to use a vice grip and clamp it on the nose of the axle. Shove the jack under the vice grip. That jack under the swing does not keep that axle end from taking a tweak, but the jack at the end of the nose kills two birds. And I'd use some huge hammer to help with the dead blow focused on the nut cut. Saves the swing, the axle, the buckle at the stand.
My deal was think 45° angle to the smack. Think of an old cb750 oil cartridge and how that oring took such a bite, squids were way too tight on that 12mm head size and rounded those bolt heads right off. They'd bring it to the shop. Here I am with [an 8yr run] tons to break loose, aftermarket came out with a 17mm head size and out engineered the head, but not the weight gain or the oring was the real secret to a clean 12mm head.
I'd have some old rusted out chisel from the 30's looks like, walk over to the grinder and put on a sharp cutting edge, I'd cut myself if I pushed down any harder to feel the shallow tip. I made the bite shaves, meaning, real close or say the opposite that of a sharpened pencil is way too weak of a tip and deep taper.
See if this cut angle works and how you bang the thickest part is to sheer away the shallow grind line open. Make a square on a piece of paper, in your head, look at a plain old nut, thread hole facing you. Look how thick the flat is; at the meeting of each hex flat. The one dimensional square on the piece of paper says to start the cut at the lower left, then end in the middle at the top of the square.
That angle says I am going to bang at the flat on the flat's meeting point is that one shot at a 45° angle. I want to open the cut and my lower right cut is not at the hex meeting point, but I am cutting a little to the right of the end of the square so my chisel is taking some wall and not an edge? I'm off the cliff with the chisel placement at the very corner of the square.
Did you see where I'd have more meat on the lower left flat hex and now 45 that sucker and one of two things happens. It sheers open it's so stuck. Or the angle of the dangle moved the whole nut.
And that means, I have to look at that nut and visually see how deep is deep and just cut no deeper than thru the ceiling and grinding into the axle's threads... I have to sit there and eyeball that kind of sheer that will occur you on the thick end of the hex and the cut over the most shallow part of the hex is right in the middle on out to a little right of the [paper'd] hex... See it?
From here and one 750 between you and me... A Piece Of Cake. For sure a dremel. The standard cutting wheel is so huge, yes, you could grind the flat many times out with a straight cut. The dremel has less to cut thru; heading up the middle starting from the end of the nut. But then again, you lost the chisel moving the angle open in a sheer. So you knock off those slices coming out with the bigger wheel. Forget me walking that out. I'm back to a dremel; earplugs; safety glasses; shop vac hose right at that drem, bungee'd to the bike and sucking from the top; a magnifying glass so I can get a closer look on the depth of the cut to the ceiling of the axle's threads.
All I want is that slice to grow out and expand off the threads. Ah, and where does the drem wheel end at the middle of the nut flat? I now want to make a cut from the end of the wheel cut and now cut across and down or better if at an angle so you have a way to cut the ring that is still around the axle at the end of the nut. Say if no joy with that single nut sliced up the farthest didn't move it, then I'd try that T-slice at it.
