I'm planning to do this run in the next week, counter-clockwise. I have ex-girlfriends I can stay with at 'D' and 'F' flags, I will probably do a cheap motel upstream someplace. Take 4 days to do the loop.
Created on: 07/22/14 01:23 AM
OpenRoad
wfozx14
RE: Sierra Nevada 500 miler
07/22/14 4:35 AM
4 days to do 500 miles? Looks like some good twisty roads.
mrwoo
OpenRoad
OpenRoad
OpenRoad
07/22/14 12:39 PM
@mrwoo....
My plans are starting to gel. I will ride Saturday from Pioneer on 88 down to Jackson, then Hwy 49 to Placerville, then 193 up to Georgetown for the night. Sunday from Georgetown, Auburn then freeway riding back to the bay area.
* Last updated by: OpenRoad on 7/22/2014 @ 12:54 PM *
OpenRoad
mrwoo
OpenRoad
07/26/14 9:46 PM
I cut part of the trip short due to heat and a fire.... but did the best parts.
Route from Santa Cruz was 129, 101, 156, 152, I-5, several county farm roads meeting up with Hwy 108 in Oakdale / Sonora for day one. Day two was 108 over the summit to Hwy 395 north, then 89 and 88 going back over the Sierra, stopping in Pioneer for the night. Day 3 basically getting back home fastest route, 88, 99, 4, I-5, I-580, etc back to the Bay Area and Santa Cruz. Damn hot out, 100 in the valley going to-from. No jacket, had it in my backpack but wore a T-shirt and still had to make lots of stops for water. Once in the high country things were much nicer, high temps at 8,000 feet and above were in the low 70's.
Meadow at 9,000 feet elevation, Sonora Pass area.
Silver Lake, Hwy 88.
OpenRoad
OpenRoad
07/26/14 9:56 PM
Also, the bike performed perfectly above 8,000 feet. It was a bit noticeable in throttle position and power, but not easy to compare apples to apples because the climb grade on these mountain passes is massive, 25%. I was able to accelerate and pass nicely at steep grade and elevation, just had to keep the RPMs a few extra clicks higher.
OpenRoad
wfozx14
07/27/14 9:12 AM
Bummer about the heat, but looks like a great ride. Good luck with the new job.
OpenRoad
07/27/14 11:30 AM
I did learn from this ride is that I can handle 7-8 hours of riding in a single day with breaks. (The day I was in the cooler high country).
Baking in 100 degree heat though is torture, even at 85 mph wearing a t-shirt doesn't help much. Need to make a stop once per hour and down a quart of water, hang out inside of the air conditioned mini market as long as possible.
If I did this again, I would make the run across the hot valley early in the morning before the heat cranks up.
OpenRoad
OpenRoad
