Page: 1 2 3 4 5
Thread: Spark plugs
Created on: 04/11/12 08:17 AM
RE: Spark plugs
01/11/13 6:37 PM
2xl gloves here, so that will complicate things slightly
Me too and that's No bueno lol Hopefully, you'll be alright. I followed spyglass advice and turned them back and forth until they got free. One was really bad though so I shot a tiny amount of W 40 on it
Bike land has a thread re: 14R plug wrench. They don't come with one
No helmet hook, no plug wrench, looks like the japs are trying to copy italian manufacturers and the Italians the japs. Oh well.
That'd make sense now they're cutting back lol
That tool will save you from uttering a lot of bad words lol It works like a charm.
* Last updated by: dragking on 1/11/2013 @ 6:37 PM *
RE: Spark plugs
01/11/13 10:08 PM
I noticed that also...thankfully...the guys that hauled my (last) 14 saved the tool kit...who knew?I mean...yes...there's one in there...from previously.(not the 14R)...it may have something to do with the airbox...there's not much room I found out...like the earlier birds.You snap a plug off...not much you can do ya know????
You know...it may be entirely possible that Kawasaki didn't want the owners to be going in and changing stuff that 'could' end up being a disaster(for some)...as much as changing plugs seems 'simple'...it can end up being a real problem if yer not used to doing it....maybe that's why..."no sparkplug wrench on this model"...IDK.Probably will be soon...as soon as they start getting reports about crosstheaded ports and all.
* Last updated by: Grn14 on 1/11/2013 @ 10:24 PM *
RE: Spark plugs
01/12/13 5:52 AM
I got the kit plug socket out last night and, in a stroke of blind, dumb luck, the large end of the 1/2"/9/16" ratcheting combination wrench (the only one I own) FITS!
pegscraper
RE: Spark plugs
01/12/13 9:17 AM
The owner's manual for the European bikes gives the plug type and gap etc. When it comes to changing them it simply states, "Spark plug removal should be done by an authorised Kawasaki dealer". Hence no plug spanner in the toolkit.
RE: Spark plugs
01/12/13 11:28 AM
I'll squirt a little PB Blaster down each plug hole and let it sit a while before I attempt to spin them out.
RE: Spark plugs
01/12/13 11:54 AM
Your bike should have one...I'd be cautious about spraying anything in there...unless you know for sure there's no porcelien pieces sitting there...Those plug covers work very well...I'd trust that if it were me.
pegscraper
RE: Spark plugs
01/12/13 4:17 PM
Before you squirt any sort of lube or freeing agent down there or even try to spin the plugs out just blow any crap out with a powerful airline while holding the tube from a hoover up top to suck away anything that flies up. I ALWAYS do this just as a precaution. JMO
* Last updated by: pegscraper on 1/12/2013 @ 4:18 PM *
RE: Spark plugs
01/12/13 5:22 PM
I'll take a peek with a mirror and flashlight after I get the stick coils out.
RE: Spark plugs
01/12/13 9:27 PM
Yes--oil will hold onto dirt in the future and make it harder to clean out.
Sounds like a very good idea. There is always gravel and dirt oieces that accumulate on top of the motor and with the rubber mat on there they may not be so easy to see. If any fall in the plug hole, next stop, cylinder wall.
I blew my motor top off before removing the plug I took out. Now I have that rubber off of there and I can pretty much see what debris lays on top....if your going to vacuum, maybe that is all you need do? Skip the blow which may dislodge debris from above and just go with the vacuum, maybe? If you never had the stick coils out, I don't see that there would be any reason to blow the spark plug holes out...unless you think something might have dropped in there after removing the stick coils.
* Last updated by: Rook on 1/12/2013 @ 9:29 PM *
RE: Spark plugs
01/13/13 5:11 AM
You guys are spinning around in circles. I've been working on motors for 40 years, this ain't my first rodeo. No insurmountable disasters yet. Besides, this ain't a Ford 5.4 motor with disintegrating plugs. Any residual PB will get cleaned up before reassembly.
RE: Spark plugs
01/14/13 4:09 PM
As it turns out, no penetrant was necessary. All 4 plugs spun out easily. I used a bit of masking tape to line the plug wrench and it brought the plugs right out. Preliminary check of clearances shows most of the exhausts (the ones I checked) within spec, but I'm waiting until this weekend when it warms up a bit to get a more accurate reading.
RE: Spark plugs
01/15/13 2:01 PM
Yeah I like to be right but I'm not going to be anal about that. There are many things out of your control that could hurt more so... blast away Danno lol
My plugs surrendered without a fight, it was that last stick coil. Did those came out fairly easy for you?
RE: Spark plugs
01/15/13 4:06 PM
I had to grab and twist each stick coil and use my other hand as a lever to exert some extra upward force, but they (reluctantly) came out. Another thing I learned was pulling upward on the velocity stacks with both hands was futile, but if you pull with one hand, you hear a squawk as they start to come loose. Then, pushing one edge upward from below, folding it to the inside of it's throat makes them come through the grommets in the airbox easier.
RE: Spark plugs
01/15/13 5:33 PM
My stick coils came out without too much trouble. I used danno's technique. The ducts come off easier with a little silicone spray lube. Pull up while pressing from below with you free hand. The duct will pull right up and the clamp will fall on the t-body bore below it.
dericrey
dericrey's Gravatar
RE: Spark plugs
01/19/13 7:40 PM
Thanks for the How To spyglass! Mine at 7,515 :
2009 ZX-14
Semper Fidelis
Violence Solves Everything.
pegscraper
RE: Spark plugs
02/08/13 1:50 PM
Mine were all like this at 8200m. Gap hardly changed from new and virtually no deposits. Think I'll leave them in and check them again around 20k.
* Last updated by: pegscraper on 2/8/2013 @ 1:51 PM *
RE: Spark plugs
02/12/13 3:07 PM
Oh now the real stories come out lol
Yeah I shot WD-40 in there, I was tired of messing with them. Checked the other day, they came out ok but I had to use substantial force. I will check again next week when I install my "gap less" plugs LOL I only have a couple of hundred miles on the new ones but I just couldn't resist my curiosity, I also got some petron additive and ordered a set of velocity stacks, so when I get that, I will have the bike on the dyno, first without the new plugs so we can see if the advertisement is true. Probably not but...
By the way Derirey plugs look a little like mine. It must be that Ethanol crap we have in TX! The gas quality among other things will dictate how religious you have to be with the book manual. Only problem is the new plugs I have are supposedly good for 12K so I'll probably go 10k regardless.
* Last updated by: dragking on 2/12/2013 @ 3:13 PM *
dericrey
dericrey's Gravatar
RE: Spark plugs
02/12/13 3:58 PM
It may be the Ethanol dragking or i'm running a little on the rich side. I'm going to stick with the 7500 mile mark.
2009 ZX-14
Semper Fidelis
RE: Spark plugs
02/12/13 6:11 PM
wrenching and innuendo go hand in hand. There is no escaping if you can't keep your mind out of the gutter!
make sure you post results if you get w/wo velocity stacks runs. It's a popular mod. Everyone I know who installed those swears by it but others say it can't do anything but look pretty and ad a couple ounces of weight.
RE: Spark plugs
02/12/13 10:57 PM
It may be the Ethanol dragking or I'm running a little on the rich side. I'm going to stick with the 7500 mile mark
In my case, I know it's both.
I heard they make your exhaust sound more fierce. I love the CT-duals sound so if that can be improved, it's almost work the $200 I'm paying for them.
I was going to test different scenario on the dyno and report back so that's no problem. I'll put all the info in my ZX-14 upgrades thread, it's about time we close that chapter.
Fowvay
Fowvay's Gravatar
RE: Spark plugs
05/24/13 6:29 AM
I realize that this thread was started last year and dragged into early 2013 but I wanted to make a comment. I've noticed that many places are charging close to $10 for the spark plugs in our ZX-14's and bike shops are getting more than that.
I was at Summit Racing a short while back and noticed that they sell the CR9EIA plugs for $6.99 each. This was the best I'd seen anyplace.
I have a Summit Racing store locally so I can't comment on shipping charges but it might be worth a look if you're ready to change the plugs in your bike.
2012 ZX-14R Green
RE: Spark plugs
05/26/13 6:03 PM
Already spent $80 on my set.
RRZX14
RRZX14's Gravatar
RE: Spark plugs
07/13/13 3:29 PM
Changed the plugs myself for the first time today. The plug socket in the tool kit made life so much better - less than 30 minutes for the change.
They don't look too bad, especially since they had 68,000 miles on them.
* Last updated by: RRZX14 on 7/13/2013 @ 3:30 PM *
Red 2006, butterfly valves pulled, otherwise stock.
"She rolled out of bed, hopped on her menstrual cycle and ran my ass over." - Walter
"If you want to be a lumberjack, you have to learn to handle your end of the log." - Harry Callahan
"He that would live in peace and at ease must not speak all he knows or all he sees." - Benjamin Franklin
RE: Spark plugs
07/13/13 7:51 PM
I gotta do this so bad. ...but I'm not about to tear fairings off and pull stick coils. Weather is too nice to wrench.
RE: Spark plugs
07/10/14 8:59 PM
I vacuumed the valve cover and then I washed it. Found plenty of tiny chunks of asphalt stuck to the valve cover and even some loose gravel that did not get vacuumed up beforehand. I applied grease to the stick coils as I pulled them in an effort to catch any debris that may fall in the well. After all of that, I stick my finger in and get small chunks of black stuff. It crumbles between my fingernails with a little effort.
Could this be carbon from the sparkplugs? ...or is it a sign that changing sparkplugs without dropping debris down the sparkplug wells is futile?
Page: 1 2 3 4 5
