Thread: 08 ZX14 filies in or out?
Created on: 09/07/12 01:02 PM
qmatrix2
qmatrix2's Gravatar
09/07/12 1:02 PM
I know that the filies out on the 06 - 07 models make a big different, so I was wondering was it worth the time to take them out my 08 ZX14. I don't drag race but I do play around on the hwy with some of my partners that have Busa. So I talk alot of junk about how 14 is so much better. Im thinking about taking them out if it give me a edge on them but not if it's a waste of time and money or if I can get the same change with a TRE! Thanks for the help!
ZX14 2008
17/45 with 8in stretch
Two Bro with Juice Box PRO
K&N filter
Speedo healer
Lower 1 1/2 front
And they call her the Black Hole
Caroobs
Caroobs's Gravatar
RE: 08 ZX14 filies in or out?
09/07/12 1:35 PM
Won't make a difference in the high RPMs, but normal riding I found it did make a difference in my 09. It's zero cost (assuming you have a good screw driver) and about an hour of work if you take your time, so no reason not to.
Read the how to on the forums and it's cake.
09/07/12 1:42 PM
Will make almost no difference. In or out, very similar on an 08-11. NOt worth it unless you just feel like tinkering. I have mine out and I feel with the proper map, the throttle is smoother at low rpm. Notice no gain down low....maybe the engine spins up tpo the higher revs a tiny bit stronger because of the initial increased flow. I guess I am telling you , "Don't expect too much." The 08-11 flies open at 3.5K rpm and no bikes really make a great deal of power below that. If you need that initial bight, you just have to launch like a drag racer slipping the clutch. That is where the real bottom end grunt comes from.
Wheelie
Wheelie's Gravatar
09/07/12 6:39 PM
I pull mine on all my bikes, I don't want "any" restriction of power.
wee
2012 ZX-14r
