Plastic air cleaner cover is gen1 and then upgraded to aluminum.
French V-stacks are restricted; narrowed down inlets.
Looks like euro/western tank vents are 2 and cali are 3 vents at the back of the tank.
Created on: 05/06/15 12:33 PM
RE: Gen1 - Gen2 Upgrades/Changes.
05/19/15 7:44 PM
roadczar
pegscraper
05/20/15 11:52 AM
[quote]See the silver alloy cross bar?
On either side see the arms that are currently tucked in?
They can be swivelled and extended outwards to attach luggage straps to./quote]
These are on the UK spec Gen 2 bikes also. It's funny, I use those luggage hooks every time I ride and I completely forgot about them!
yannih
05/20/15 4:00 PM
Those luggage hooks we have on the Australia spec'd versions that the US boys don't have must be the reason why we pay thousands more for our bikes.
Lucky us...
* Last updated by: yannih on 5/21/2015 @ 4:24 AM *
pegscraper
05/21/15 12:15 PM
[quote]Those luggage hooks we have on the Australia spec'd versions that the US boys don't have must be the reason why we pay thousands more for our bikes.
Lucky us.../quote]
Oz is much closer to Japan then either the US or UK so how come? What's the drive away price of a new 14R/ZZR1400 down under? I paid £11500 for mine in March'12.
yannih
05/21/15 1:13 PM
Brand new 2015 ZX-14R $21,799 plus on road costs here.
Our government adds a nice chunk of duty and tax plus the Australian dollar exchange rate also plays a major part.
But again, it's okay.
We have the retractable luggage hooks...
* Last updated by: yannih on 5/21/2015 @ 1:16 PM *
yannih
07/10/15 11:51 AM
GRN found another one.
No need for an Evo Shift Star kit upgrade because the OEM shift arm has been updated with a bearing on the Gen 2.
The list keeps growing...
* Last updated by: yannih on 7/25/2015 @ 4:13 AM *
johneturbo
02/10/20 2:46 PM
Mainshaft gears differ. Top input is 28T for early, 29T late. Both top outputs are 29T. Countershaft gears have different part numbers.
The X-Y factor is if the case spacing went wide/narrow and the shaft protrudes or is recessed. Next X to Y is if the shafts are spaced, where this says the gears jam up or are spaced farther away at the tooth to tooth gaps.
johneturbo
02/12/20 11:13 AM
Thanks for the reply Hub,I've ordered it off eBay the seller is adamant that they are the same!
Will I know if it's different from comparing them together? If I fit it in the lower casing I guess if it fits then it should be ok? Or is the main drive gear different which I guess is what you mean by input gear?
Thanks
