Thread: Getting Close to RACING!!!
Created on: 03/29/16 02:54 PM
bgmagma10
bgmagma10's Gravatar
03/29/16 2:54 PM
So I pulled my motor over the winter to mainly do valve springs for spray this year. Of course since I had the motor out I might as well do a little extra. My close friend owns a bike shop and is a well known motor builder, so he Milled and ported my head, and had a regrind done on my intake cam.
I put my motor back in over the weekend and she fired up first try without any issues! Now she will be on the Dyno tomorrow and Testing next weekend for our first race April 16th! I'm so excited for this season to start I can't stand it!!!
RE: Getting Close to RACING!!!
03/29/16 3:26 PM
So you need to remove the motor tto change valve springs? I'm sure I won't do that this season. Next winter for mine and maybe I'll do some of the engine mods you mentioned. I'll be curious to hear how much hp they net you. I'm guessing just 5-7 hp but it all ads up.
chrly
chrly's Gravatar
03/29/16 6:07 PM
BG.. where do you race ? or what organization?
bgmagma10
03/30/16 6:13 AM
Rook, you can't get to anything on the top of the motor without dropping it, but it's not hard. It should gain 10-15 horse but I will know how much it helped with I go to the track.
Chrly I'm in Tulsa. We haVE PMRA here. We have races here, Noble, and Wichita this year.
03/30/16 8:03 AM
I envisioned it being a continuation of removing the head cover and camshafts but I guess not. I guess I'm ready to remove the engine but it will be a whole winter project for me.
What do these mean? Cams, I understand you have ground a few degrees rounder--you cut the lobe a bit closer to a circle--which holds the valve open longer, righht?
Milling the head is shaving it so the combustion chamber is lower(shorter) which gives you higher compression, right? What is "porting" the head?
That definitely sounds worth it. Mind sharing approximately how much this would cost the ordinary guy walking in to have his cams and head reworked? I might want tbodies ported too on my gen1--maybe.
Engine work makes me drool. I'm dreaming of the day when I need some big chunky connecting rods and a HD crankshaft. That will be the turbo days which hopefully are coming in the next few years. i hope I get there before electric engines take over.
chrly
chrly's Gravatar
03/30/16 8:17 AM
BG, trying to arrange to make one of those races as two friends race the same group. Neither have their bikes ready at this point.. I am thinking Sept 10th will be the meet .. Are all three tracks 1/4 mile?Would I need to do anything special to run back there, I belong to NHRA and am licensed.
* Last updated by: chrly on 3/30/2016 @ 8:18 AM *
bgmagma10
03/30/16 9:17 AM
I planned on pulling my motor in the first place, you may be able to do it without pulling the motor, but it's definitely easier all around if you do.
Having a regrind done on my cam increased the lift. Since it increased the lift it also increased duration (valve is open longer), if you increase duration you lose compression. Milling the head brought my compression back up. Milling doesn't change the size of the combustion chamber, but moves the pistons closer to the valves. Thats why we didn't go with that big of a cam, cause I would lose to much compression. The factory ports on the 14's look REALLY good, but down closer to the valve seat it was pretty rough. He just smoothed that out on both the intake and exhaust side. Just a little on the exhaust side.
Man it all depends on who you go to. Some big name guys charge $1200 just for head work. It also all depends on how much of the work you can do on your own to save labor costs. If you drop your whole bike off to have it done it's gonna be really expensive. If you pull your motor yourself it will save a bunch of money.
Roughly just what I have, i'm not sure on prices
Valve springs $300
milling and porting $500-1000
New head gasket
Cam regrinds $350 - I think
Then whatever labor your shop charges.
bgmagma10
03/30/16 9:29 AM
Man thats awesome!!!!! Lol i'm in the same boat as they are! Yes, all tracks are 1/4 mile. If you're NHRA licensed you should be good. These are really the basics they check.
tether kill
chain guard
tail light
and of course leathers
but I think thats about it. I will talk with the committee and make sure i'm not forgetting something. Should be some damn good racing this year! I was hoping to run top gas on the motor, but I don't think it's gonna be quick enough on the motor.
chrly
chrly's Gravatar
03/30/16 9:54 AM
Be sure and post up when you are ready to run.. Would be great to meet Board people And old friends ..
bgmagma10
03/30/16 11:33 AM
Will do man! we have radial revenge this weekend, so hopefully test next weekend before the April 16th race. All the guys on the board are all super cool! Looks forward to meeting you man!
03/30/16 3:51 PM
thanks for the info. i have a link saved to this thread along with my 47mm tbody info---F anyone's I, for the gen1, I was told you need the head and cam work to really make the bigger tbodies effective.
* Last updated by: Rook on 3/30/2016 @ 3:55 PM *
chrly
chrly's Gravatar
03/30/16 7:30 PM
BG, looks like Sept 10 will be the only weekend that I can make without losing races here..So hopefully, I will be there in Kansas...
bgmagma10
04/01/16 7:28 AM
Hey man 1 is better than none! It's gonna be a good year!
chrly
chrly's Gravatar
04/02/16 3:18 AM
What do you think about running Super Street?? Right now I'm running 9:60s no electrics and foot shifting..
bgmagma10
04/04/16 11:36 AM
Man , I thought about having my throttle bodies done, but after talking with Lee about it I decided against it. Hopefully it works out for you.
Man I will tell you Super Street is tough competition. Most all the guys that run it thats all they run, but there's always a good turnout.
04/04/16 4:03 PM
Well, this will be no sooner than a year from now. Perhaps the Gen1 will be all but forgotten by then. You already have bigger Tbodies with the Gen2....I believe I heard the stock Tbodies were as close to perfect as can be (that might have been something you posted in the past year)...so who knows? I'd have to research that one more. About $600 to port tbodies and lath the secondaries shaft down to ~1/8". One good thing is Tbodies are not too hard to change so it would be possible to test OEM v ported. Hope someone else has already done this so I can stay $600 richer (or 600 less poor, as it were).
chrly
chrly's Gravatar
04/04/16 9:08 PM
BG.. Just realized that teh 16th AND 17th are both race days... It is so tempting that I even checked the weather :)...How does teh Org handle rain? Man 1860 miles one way would be a bummer to get rained out LOL.
Question can you run two classes ? I was looking at Super Street for sure and mabey Street Et ?? I have no electronics or clutch help.
bgmagma10
04/05/16 9:34 AM
Man If I were you, I would talk to Anthony De La Torre. His 1st gen is nasty stock bore stock stroke. I do think he has bigger TB's as well.
Man they are usually on top of the weather the best they can be. If there is a pretty good chance of rain they will usually call it by wednesday or thursday. Or at least have a plan by then.
chrly
chrly's Gravatar
04/05/16 6:40 PM
Ok Guess at this point I am going to hold off unless there is a drastic change for the better..I will watch the site..
* Last updated by: chrly on 4/5/2016 @ 6:40 PM *
bgmagma10
04/06/16 7:00 AM
ok man, I will update on here as soon as I hear anything as well.
chrly
chrly's Gravatar
04/06/16 7:07 PM
Thanks..
bgmagma10
04/14/16 10:05 AM
Looks like the weather is going to cooperate this weekend! Hopefully it stays that way.
chrly
chrly's Gravatar
04/14/16 6:11 PM
Thanks BG but too late for me to leave and I was watching too . I kept seeing T Storm warnings from one day to the next and decided to just run the two days here a lil closer ( Medford Oregon) at Champion Raceway.. Good luck !! If you have time, take pics..
bgmagma10
04/15/16 11:12 AM
Thats cool man! Probably safer that way. Sunday is still up in the air, we have a chance of rain but we will see. I will man! I will take my camera and get some pictures form the wall of the big boys! Good luck this weekend man! Hope all goes well!
darkarcher
darkarcher's Gravatar
Cincinnati, Ohio USA
04/15/16 11:27 AM
This post bums me out, I want to see you and smokin going at it for the stock motor honors this season bgmagma! But just because I am bummed out doesnt mean you cant go ahead and post those dyno charts. I assume you are going to see something to the claims of what carpenter racing offers.
2020 on the way!!!!!!
