From: STEPHEN MOSSMAN [mailto:ssmossman1@xtra.co.nz]
Sent: Monday, September 16, 2013 2:35 PM
To: Syx, Steve
Subject: Re: Contact Form | Advice@BrocksPerformance.com | Mossman
Bikes running Yoshi cans and original headers. Mirrors removed and number plate gear removed.
Im slim build 80kg.
Petrol type mobile 98RON
Temperature was very low at 8deg Celsius with slight tail wind
tyres bridgestone 20s set at 45pounds front and rear.
Run up was just over 1mile before beam break start and finish.
clock reading 2 mm past 300kph indicated at 3/4mile 10500 rpm and no further increases.
Recorded average true speed 293. Lowest of 6 runs was 291.7 and highest 293.
Turbo Busa running 345kph
2 stock busas limiters removed running 300+
R1 with very small rider 304kph
2013zx10 rider same weight and limiter removed 303
My last email.
Response
The first things that you will want to do is one of our full systems and a power commander with our map. That will get you a lot more horsepower. Slip-ons really don’t give you much power. Also if you can find gas with a lower octane that would be good. We run 89 octane, 98 is more than you need for a stock motor and is hurting your power. You will also want to lower the bike, the lower the better, front and rear.
Thanks,
What annoys me the most is no offer to check the ecu has received a full flash. I paid 375 and over 100 freight which in nzd plus import tax is a weeks wage. I have the ecu out and ready to send and would have paid freight again without questioning it but the least I could expect was for an offer to check it for me.
I wish I hadn't already ordered and paid for a brocks pre programed pcV 2 weeks ago which hasn't arrived yet.
Shipped To...: Stephen Mossman
5 Adams tce
Aro Valley
Wellington, NZ 6021 NZ
By Carrier...: USPS
Notes........:
Ordered On...: 8/31/2013 5:36:51 AM
Shipped On...: 9/3/2013 3:49:11 PM
Qty Part
Line# Part # Ordered Description
1 923293 1 Dynojet Power Commander V
2 MAP8 1 Track Map for Pump Gas
* Last updated by: Towball on 9/17/2013 @ 2:14 AM *
