... Do not step on my car pit, d-is pit speak, wear out I sneak up on year trophy, you go racing withe turtle talk.
The first line of defense [filter] is a band-aid fix. If the porosity is that flow-able, so says the 2nd filter is looking 1/2 as bad with the microns that did move past the first line/0d filter. Then say, a 1/4 of those microns attacked the blade and wiper cage finish.
If you could [collect] and line up the tiny gouges, gave depth and width to it, we have an air gap, a liquid gap, a pressure loss gap. I am now 1/8 of a micron, was swept under the blade and my ass got burnt. I am now down to a 1/16 of a micron, and am heading for a spray hole opening at the injector: along with my ass burn. I cannot create or destroy ass burn, so I will collect like bird finding twig. I'll nest all my micron ass burn is sit here is to give you a spray like if I held my thumb over a hose and let the water shoot off to the side, I cloggedat assideways.
And you know that cage wipe is also material gone [unfiltered] meaning, hose say can you see is me thumbulleanHA?
I'm in the hole close to 80 bucks adding new rubber on the tank seal too. I can only change one filter and both look about even as per micron movement. I'm still looking at wiper blade and cage wear, where I have to reach around the postear we are back up front to the zipper, pissing away 100 bucks worth of shipping is the total? I'm looking @ 42 psi with a $100 filter is a 1/3rd of the filter is repaired. I'm going to clog more of the 2nd filter that's 1/2 clogged already. Ah, 40 psi and; 'Hi, new here. When I WOT her, she falls on her face. It's all stock. Leak in all 4 read 2% leak. It's not compression. I changed the plugs to OEM to keep that variable out. I have spark/compression/WOT do you think is left?': Is one variable = Fuel pump pressure for $300, Alex.
I have my $100 half/ass'd filter on. I have the other filter like a front sprocket I'll leave alone. Wear out the new rear sprocket and new chain over the old sprocket and eat that up in 1/2 the time is the front sprocket is well over 1/2 done. I need to keep the used front wheel on the bike with the new rear tire and hammer into a corner with a used front, look ma, no KFC's on the front!
Ooopseas! My bike did some lawn care on someone's property. I thought I had more rubber on the front?? So I'm back at the dealer's counter, they won't lose a sale matching net. You win with no shipping. Your second round of fuel slobbering out the 10 or 12 holes, she is going to have more yuck behind her orifice-is might ass well reach around, have the injectors cleaned while you're at it.
You have this 1st defense drag heading up to a second, wink-wink, sea change is wear out I'm going ~ rev-rev??
