Thread: Need Suggestion: 12vdc Tap in
Created on: 05/12/23 12:04 PM
csmall
csmall's Gravatar
05/12/23 12:04 PM
Hi,
I am replacing my Healtech V1 Gear indicator with a V2 as the V1 Died. The old one had it's power source connected directly to the battery the new one needs a ignition switched 12v source. I am trying to tear the bike apart and was hoping someone can suggest a tap in point on the left side of the bike. Does anyone know if the connector directly above the coolant reservoir fills that need? Any suggestions would be great, thanks.
* Last updated by: csmall on 5/12/2023 @ 12:04 PM *
2007 ZX14, Midnight Blue/2011 370Z Albuquerque NM
piken
piken's Gravatar
RE: Need Suggestion: 12vdc Tap in
05/12/23 1:28 PM
(2012+) Up front, under left cover. Switched Hot lead going to the horn button.
You can tap in there.
ZXAdventure
Freeland, Whidbey Island, Wa
07/29/23 12:12 AM
The Zx14r has a switched hot lead on the left side. It is listed in the manual. It is under a cover, covering several connectors
* Last updated by: ZXAdventure on 7/29/2023 @ 12:14 AM *
Lawrence Douglas
