not a how to...just what I'm doing
7500 mile service... throttle body sync, bolt tightening, and a few other things. I also have a couple other minor issues I'm addressing which aren't related specifically to the service interval. Clutch fluid need changed and my CTEK's charge lead indicator led readout (green/yellow/red leds) stopped working. 7500 mile service calls for spark plugs but I changed those out at the end of the season.
I was hoping to change tires and do an oil change but my Q3s have a couple hundred miles left on them still. And I'm going to wait another 500 miles for the oil change (4k miles). That should get me through to the end of the season
Started last night, got body work off. I considered the CTEK charge indicator stopped working due to battery terminal corrosion. I pulled the battery, negative terminal did have quite a bit of corrosion build up. I cleaned that but it didn't fix the indicator issue. The CTEK 3300 charger came with one so I put that one on. It doesn't have the cool little led read out though. I'll have to order another one of the led equipped leads and put it on during the off season.
Here's a pic of my (now old) clutch fluid. The factory fluid was even worse, and was definitely affecting clutch operation. I bled the clutch mid-season last year, as hard as it is for me to believe it's this bad already. Clutch operation wasn't being affected like the OE fluid. But figured no harm in bleeding it anyway. I bled the f/r brakes last year and the fluid looks fine/normal at this point.
I synched the "carbs" (throttle bodies) today....
Used my "highly accurate tachometer" to verify engine rpm was in the proper range
after sync (also notice the fresh clutch fluid...and also you can see the front brake fluid which looks normal).
Tomorrow going to do the rest of the checks, and get the bodywork back on!
* Last updated by: VicThing on 5/16/2015 @ 8:20 PM *
