Hub just changing how we burn fuel has a effect on hp... should it ?
Absolutely. I have those two different sounds (utb'd that for the ears) as they cut fuel richer. Why? Wire-wire-pants on fire. L for _______Flop in the blank you flip the wire fandango.
Hub U B messing with me. I know you don't believe that, fish on again.
I have yet to cut and paste the ECU so whatever that effect does, I have yet to find out. But say it's a buzz or tone change. I can sense something by hacking all those sensors and following the book's code page. So like I said, I can do a lot of outside flip/flops, but I'm sure the flash is the quicker setup, or you're looking at my rigearsmearoll out and test c0ode hits 1 at a time. And I mean, some of the changes you can make like the limiter and fly tricks.
Sound like a limp to you? Brock says...
He didn't say it: the numbers did. So is she full sub open on flash? Goes out into the fresh air and the signal changes to what? Mav lost mph but gained ET. Where are you seeing this hp gain with flies out/100% open?
This is out of context. Talking about the affect flies on top end here. Dyno Talk.
Agreed? What map says to run 100% open I cell everyone to 100%. That means Mav has 100% open flow of the sub, correct? Big point here is me being alone and putting 2&2 = 4 Subs saying something down that 1320 or on the dyno says the same thing.
Real World; What is not told is this 14R made it's fastest runs with flies out.
ET you mean, and we agree. Now, bring in the mph vs. BMF (before Mav flashed). I want to get this real world straight, because I am losing my reality on line LOL
The cooling affect of the moving Ram air is Not in play on the Dyno.
All I see is a lower et and a lower mph I watch the weathervane.
Take your AFR line on the dyno, now run 200mph and look at you AFR line, are they the same,,, Maybe I catch a fish lol
Ah, If I only knew the AFR number I plug in a flashy fish. You got me on that. I'm 14 and change all OE no PAIR. Unless I pc up I can run 13 and 12's, accel mode, etc. So I'm sure a hack and a pc is the same kind of grunt buzz or tone I get and say you combine that tone/buzz all in the grunt at the bottom, yes? You say yes, that's like a (tape over my mouth) pants on fire outside the cell move.
Hub this sort of preaches stay stock, these were our convos of old. Always ended with the word "Limp"
Funny how that computer bike works, hey? Fukcup my frequency. Here we go again. You remember my little run in with a benz coupe? The bike was wired up with 5 toggles and I'm trying to close down each one. The more I pinged to stock the stronger the bike.
When in actual fact you and I both know that gen 1 bike has factory tuning issues that could never be fixed with pigs alone.
Shit, I had zip problems getting the bike smoothed out. Slap myself for not thinking about the tune up long ago it ran so smooth. The R is not even close to a (smooth) tune. Looking back, I never plugged PAIR and found more (rich) smooth as the AFR pointed out. Look at how more I had left.
Not on yet, mostly because you never got on lol
True. All I have to go by is the thread and the OP's R&D. That Hutton speaking and when he speaks, that's a lot of tires, fairings, wheels, suspension, and when the flashion came into fashion and under his ass it shall meet, you'd be listening by now or catch on, yes? One or the other. Better listen, because he likes running with the ball. I'm about 3 seasons short of catching up and losing groundontchewknow.
