has anyone installed a GPR or Ohlins steering dampers on thier zx14?
I was looking into them wanted to get some input before buying. I have had them on previous smaller bikes.
let me know
thanks
2007 hayabusa black out brocks and vortex everything..
Created on: 03/02/09 01:49 PM
jlcumb2
STEERING DAMPERS
03/02/09 1:49 PM
let me know
thanks
RE: STEERING DAMPERS
03/02/09 5:49 PM
I have a Scotts on my bike.
Might save me from a slapper if the front was to ever come down hard at high speeds, but for the most part a damper is unnecessary on a zx14.
zxbob has an Ohlins.
masszx has a GPR (haven't seen him here yet though)
* Last updated by: DogoZX on 3/2/2009 @ 5:50 PM *
BigDan
ZXtwitch
03/03/09 6:40 AM
I plan on getting a gpr for 2 reasons. first since I lowered the rear of my bike it seems to handle better but is more susceptible to head shake (probably from upsetting the geometry of the bike but its cool cause I think it handles better). and 2 they make you have a damper to run the Texas Mile, and I really want to give the mile a try.
BigDan
jlcumb2
jlcumb2
Hotrodnut
03/17/09 8:33 AM
I have the Scotts, the reason I went with it is I've had it on other bikes and had no issues with it or any head shake, tank slappers or ill effects while installed.
I really had a hard thoughts of having to drill holes for the install though, but the kit comes with a punch, drill bit and tap that made the job very simple.
I looked hard at the GPR and probably would have went with it if I had ever had one with good results, mostly because I wouldn't have to drill holes in the frame.
The little I have gotten to use the Scotts on my new ZX-14 has given me good results and only had one occasion that it may have helped, coming out of a turn at pretty much full tilt and crested a rise under power which both wheels got light and jumped a foot or so to the side with nary a wimper from the front end!
wfoshawn
wfoshawn
03/28/09 6:31 AM
I bought my 08 used with 2k miles. The first thing that I did was put new shinko 05's on it. So it is not the tire.I'm guessing the bearings are a shade loose.I've seen these do this after initial break in or after the first couple wheelies seat the bearings fully.
russty
03/30/09 6:33 AM
My 08 is the third new bike in 20 years, first the 88 Yam XJ900, then the 98 Yam R1 until third time lucky with the ZX14.
Every time, I take the bike to my favourite mechanic and have them pull the bike apart, re grease all the bearings (cause the factories don't do it properly) and reassemble correctly, tensioned etc. Using this approach, I've never had a loose or worn bearing. I pulled them all apart at the 10 year mark and the bearings were as good as new with 10 years of perfect performance. I hate flat steering head bearings!!!
I recommend the same approach for you all. The bike always feels like new...
newf14
BigDan
03/31/09 7:41 PM
wfoshawn: I have noticed that my 14 wobbles when I let go of the bars.Might just be too loose?
I've heard of this problem before. The bars are fine with your hands on them but if you lighten up your grip to almost just touching or actually let go, they shake. What I remember reading is that it could be a loose bar end weight. If you have aftermarket bar ends, you might want to try switching back to OEM and see if you still get the shakes.
Hotrodnut
04/01/09 5:29 AM
The only time I have ever had a wobble like that in the bars in the 43 years of owning Motorcycles has been from a front tire being slightly out of round or way out of balance.
I even had a brand new Michelin wobble from new, they made it good with "Bib Bucks" certificates for a new tire.
masszx14
masszx14
BC14
Jeff01ss
mash
05/03/09 9:30 AM
Hi everybody, Im new to the site. I have a GPR on my 08 and really like it. I did have to modify the post that bolts thru the top of the shelter that hold the damping arm. Maybe they packaged the wrong piece for the bike it did not sit flush with the arm. I have had them on alot of other bikes and there customer service is great.
jlcumb2
05/13/09 9:07 AM
Jeff01ss
I have the GPR with 1 inch heli bar raisers. no problem at all... I strongly recomend it i have road for hours bike stay straight and no wrist cramp.
Jeff01ss
