Just put a 4to1 carbon fiber muzzy on my 2012 ZX14,not sure what route to go seems little boggy now until 3000rpms. Should I get a power commander 5????
Created on: 12/24/12 07:22 AM
tj7501
Power commander 5?
12/24/12 7:22 AM
RE: Power commander 5?
12/24/12 9:43 AM
Wouldn't hurt. You've effectively leaned out the mixture (air/fuel ratio) by replacing the stock exhaust with the less-restrictive 4-into-1.
12/24/12 1:00 PM
1st Choice, ECU mod for faster fly opening = more bottom end snap. plus plus plus
2nd, remove Flies. This will cost you some Hp up top.
I was taking a good look at the fuel cells in the area below 3000,,,,, PCV will not give you what you want.
tj7501
12/25/12 9:44 AM
ECU mod? What is it and where and how do I get it?
12/25/12 10:39 AM
Call Ivan
Ivan's ® ECU Flash for this model includes: - Available Now!!
1) Speed limiter removal
2) Raise rev-limit 500 rpm
3) Traction control off completely when selected - no more safety mode in the lower gears to slow you down. (6-15-2012)
4) ECU remembers last traction control setting - so you don't have to turn it off every time you start the bike.
5) My tuning program .
Throttle "quality" is flawless in the corners.... it makes rediculous power and good mileage as well with no flat areas
(no matter what you do with the throttle... even at low revs)
6) Bike runs noticably cooler
7) No TRE needed - all done inside the ECU.
8) Our flash is not the same as others available elsewhere.... it has very specific items done to Ivan's™ exacting specs....
nothing was left out that would compromise any aspect of performance.
All testing was done in house on Ivan's personal testbike
JC
01/12/13 7:50 AM
A PCV with the Auto Tune Kit will not adjust the mixure with the add-on sensor on the exhaust line?
See the below link:
http://www.powercommander.com/powercommander/Products/AutoTune/powercommander_autotune.aspx
ZX14MAN64
