Thread: NOS Tips
Created on: 11/08/09 07:07 AM
NOS Tips
11/08/09 7:07 AM
Ok thinking of putting NOS on the 14 could use some install tips from the experts, to see if its feasible.Only going to do a 40 shot , so my question is what if anything needs to be beefed up? and where is best place to install the 2 nozzles? And for just a 40 shot can i get the extra fuel thru pc3 alone?
thanks guys
Slowninja
RE: NOS Tips
11/10/09 4:58 PM
don't NEED anything beefed up.
high performance valve springs are recommended but not necessary.
I personally like my MPS spyder spray bar. it uses 4 jets, injects the nitrous straight into the throttle bodies so you get a true 40 hp from it.
You have an 08, meaning you have the larger injectors. You'll be fine using the power commander for the fuel. IF you're crafty with wiring you can hook your map switch up to the nitrous switch (activates the nitrous and switches maps at the same time.. this is how i have mine set up).
I think the site is mpsracing.com .. they sell the entire kit
Resident Drag Racing Expert.
ZX-16 in 2010
8.64 at 158 on motor
8.28 at 173 on nitrous
Back to stock for 2011.
9.24 @ 148
185 hp pump gas
RE: NOS Tips
11/10/09 5:36 PM
thanks slow i seen that spider bar (wicked) do you use a button to activate or the auto wot version
RE: NOS Tips
11/10/09 5:40 PM
slow is there a wiring diagram out there for that setup?
Slowninja
RE: NOS Tips
11/10/09 9:04 PM
i use the horn button for mine, since my horn is no longer on the bike.
I've seen it around and i'll look for it. I didn't use one when i did mine, it really is simple if you take the time to think about it. I've got two relays in my system, the horn button activates both of them. One is for the nitrous (just cause i like relays, i think its safer) and the other is for the map switch. If you cut the map switch wire, you'll see that there are actually only two wires going to it. meaning NO = one position and NC = the other. (i dont have my bike here or else i would be more specific). Wire the relay up in place of the switch and your map will switch when you push the horn button.
I can draw up a diagram tommorow if it'll help.. too tired tonight its past my bed time LOL
ZX-16 in 2010
9.24 @ 148
185 hp pump gas
RE: NOS Tips
11/11/09 4:47 AM
thanks slow would be much appreciated sounds like the way to go
RE: NOS Tips
11/11/09 6:21 PM
NOS on your bike will be so cool. I would like to do that one day.
Slowninja
RE: NOS Tips
11/12/09 5:15 PM
its easier then people think..
And if you use a speedcell battery, you can hide your bottle inside the battery compartment.
sorry i still haven't drawn a diagram... i'll work on it promise lol
ZX-16 in 2010
9.24 @ 148
185 hp pump gas
RE: NOS Tips
11/12/09 7:33 PM
Just don't let this happen
RE: NOS Tips
11/13/09 4:30 AM
damn rook youd of thought the camera guy caught on fire lol
