I never use grease on the axle
This is why you should. The bearings sit in that rim and there is air between that distance to the other bearing. We need to have a collar in the middle of both bearings so when squeezed, the balls are pretty much centered in the race when the axle is tightened. We know the outer bearing race turns, the collar and spacers keep the inner race stationary on the axle clamp. We have that picture?
We are still fighting an air space. We live in a wet climate. Damp is the air. We let the bike sit in dry climate but in the garage with the dryer going and now that wet out of the clothes dampens the garage with the heat off the dryer, etc. Follow the ambient and is not the air gap in that rim following room temp? Yes.
So are we not also riding and causing heat to build in that air tunnel between the tube and axle? Tires warm up the rim. Brakes heat up the bearing along with the rolling there of. How much moisture do we have in that dry cave of a steam bath happening and why is there rust on my axle too? I had to beat my axle out with a hammer, the stalagmite made my axle tight is a rusty shallow place to keep air from entering if its in there sort of sealed off already.
If we had a vacuum in there, no part is about to rust, but that's the deal in that area is why you should grease the collar a lot as well, if you decide to grease the axle.
Signed,
Make Sense?
