[quote]Scottjkyl, where did you mount the front and mid lights there?/quote]
caroobs on the front there are 3 5" strips on the underside of the nose and 2 10" strips going down the back side.and a 5" strip on top of the speedo (rear)
the mids there are 3 5" strips on the plastic shield over the radiator and 2 3" strips (1 each side rear mid) attached to the frame over the tranny
the rears there are 2 5" strips up in on each side over rear tire, 1 3" strip attached to the back side of the rear brake caliper (shining in on the wheel, 2 5" strips 1 each side on that inside frame under the seat, and 1 5" strip on the plastic box in front of the swingarm facing the rear of the bike
