From AlienHead to CT singles or Duals, I don't remember seeing any numbers under 175 hp so it's definitely not the pipe. Your torque is pretty low too. I barely cracked 100 and thought I should have been at around 102 but crisp and cool weather should give me an 180hp-102tq so I'm waiting for fall for the custom tune! Brock will probably tell you to get rid of the K&N and go OEM as far as the filter go. I have read that some make you loose power. Check the ZX-14 diary on Brock's website.
I couldn't read what temps your dyno pull was done in! The graph above is the first and only pull and it was humid and close to 90 degrees that day! I'm using a stock filter with the back screen removed, filter had about 6k miles on it. Also how many miles on your bike? 08-11 take longer to show their true potential.
As far as the Brock's numbers, mods are on the graphs. The 187 hp ZX-14 has o weight oil, o-ring-less chain, and maybe race gas. Basically it's set up for the strip!
Kolk is right though... you're not that far off of the average I'm seeing with the same mods and you're on a different dyno in hot and probably humid Alabama!
* Last updated by: dragking on 6/30/2013 @ 8:22 PM *
