![](http://i149.photobucket.com/albums/s58/wazfst1tyme/Nov-stackidea.jpg)
![](http://i149.photobucket.com/albums/s58/wazfst1tyme/Gutguardless.jpg)
The CAN Con:
1. Smash the cat out, you lose a slight bit of grunt. Yes, it is a slower-downer, but I left the cat in the bag.
2. Why cut the stocker up. This is your best gruntune are the stock pipes. Do not tamper with!
3. That price balance.
4. Oh, I gutted [1] stock can. If I really tore up some rpm, that one bolt holding on in the back, would move the cap out that wasn't secured well. WOT a pain that was taking a rubber mallet to it to send it back home. I was going to somehow quiet it down inside later sometime. Why rivet it back closed was the idea.
5. I installed a bearing over the back exhaust hole to quiet it down, being the outside idea. Plus, I used an early model header without a cat. My idea was to run a sleeper 4-in-1. During the low grunt applications [that were slightly lost somewhat] due to the one pipe mod, like you, I still wanted both worlds. No longer could she jump, say.
6. On went the proverbial 'muffler bearing' to quiet the home front are the neighbors getting on my case. No, they didn't. But that noise got to me. The grunt got to me too.
7. Returning back to stock, what grunt I remember was all over the place, but you did feel that lag come in, meaning, not as free flowing. Because you want that air release to happen.
8. And again, the compromise is back in the game with the photos above. Took me a half hour of pain I'm paying for working on this cheap throw away for a miserable tune up.
9. This thing sounds corny now. I set my hand in the back of both pipes and it's WOW! WOT a pulse coming out of that thing. Niiiiice.
10. Other than the obnoxious noise, It may also give the 02 a wrong read sort of. Thus the eyesore at the AFR begins.
The PRO Side:
A. The hand balancing act of the price of parts is parts. A full exhaust being the 4-in-1, will lighten the bike. Will lose the grunt. Will open the top end gain. You eat both that price and the grunt. You can't have it both ways, take the pill and swallow it. HP gained. Grunt so-so.
B. The cat gut call. Either side wins. I see no difference in that slight move if closed course is all about speed and HP. But the pro side sort of looks at the fatter header to compensate for a screen that is on the back of the air cleaner sort of flow. Not much, but a change in flow none the less. Remember, this is the pro side and you sit home on the couch now. This is for all the guts [out], all the marbles of torque are for the birds.
C. The dual set. The price balance and I have 3 different combos to choose from. DO I?? Buy the duals, gut the cat combo? That is one way to apply speed out the back.
D. Do I run a cheater dually? Gut the dual I just bought new and keep running a cheater beater noise machine?> One more option on the pro side.
E. Dual gut job I keep pro siding on the insiding. Your second option on the chopping block.
F. ING A, look at that cheap asshit design. They should cut up the other brands, see what is going on. The internals of this pile needs some work. No V-stacking. A decent idea out, but to match the guts of the 14? NFW hose say!
G. The pro side is that if you do not like all that extra modding on the aftermarket side, the pro side says there is a grunt side waiting in a box... The OEM = Untampered with. The extra grunt waiting in the wings was that take off to put on less grunt.
H. Is for, Homey does not use no stunk'inn fuel cutter on a muffler'd pipe. That is the beauty of open loop.
