Thread: "Low Fuel" indicator - whats yours?
Created on: 01/03/10 03:47 PM
JDC
JDC's Gravatar
01/03/10 3:47 PM
First time since putting on the turbo, Feb 09, that I got the "Low Fuel" indicator. Went to the gas station and filled up with 4.8 and a hair gallons. Prior to the gas tank mods I'd get about .5 gallon plus reserve notice.
Not much 'reserve' notice now.
Whats amount do you all have in reserve when you get the "Low Fuel" indicator at first on?
* Last updated by: JDC on 1/3/2010 @ 3:48 PM *
RVTECH
RVTECH's Gravatar
ORANGE COUNTY NY
RE: "Low Fuel" indicator - whats yours?
01/03/10 5:40 PM
SAME HERE 5 GAL BEFORE MODS HAVE NOT BEEN OUT YET AFTER MODS I'M CURIOUS MY SELF,BUT NOT @ 18 DEGREES.
07 ZX14
FULL MUZZY
K&N FILTER
POWER COMMANDER (CUSTOM MAP BY JEFFO)
01/03/10 5:47 PM
You must have read my mind. I was thinking the same thing today.
1. What does the mileage read once it triggers the low fuel light or gas pump icon?
2. What was total range before the tank ran out of gas? [like anyone would admit to it]
JDC
JDC's Gravatar
01/03/10 6:22 PM
I'd average about 100 miles before low fuel signal, 50/50 city and highway hot-rodding under boost.
The range is completely off so I dont use it. It is always way optimistic to reality, since turbo.
01/05/10 12:25 AM
Ran mine to the low fuel indicator.Rode for another 5 miles.Stopped-filled up.It took a tad more than 5 gallons.Book says-.8 gals-low fuel indicator comes on.Mine was pretty darn close.With my 16/42 gearing-I average around 34 MPG.5 X 34= 170.Taller gearing will give ya more.
* Last updated by: blue07 on 1/5/2010 @ 12:27 AM *
extrapilot
extrapilot's Gravatar
01/05/10 4:49 AM
1.1 gal is the listed reserve I think. I can get over 200 miles running thru the reserve.
hoopie
01/05/10 7:09 AM
i get 4.8 gallons roughly when low fuel light goes on. Ussally around 165 miles. I average 36.8 mpg
2008 Kawasaki ZX14 Saphire Blue. Yosh R77 Full Titanium Exhaust, Power Commander 5, Custom Map, TRex Frame sliders, MRA Touring wind screen, Speed Tactics fender eliminator, Heli Bar Risers, Lawst cause frame plugs,Ketie Tank Pad
NC2VA
NC2VA's Gravatar
01/05/10 4:01 PM
I can't seem to get over 30 mpg, with just normal driving, 50/50 highway and street. Mods are just the basics full pipe, pclll, bmc filter, flies removed, speedohealer, and -1 on the front sprocket. The bike hasn't been tuned but runs good, maybe not as good as I think if I'm truely lossing ~6 mpg.
ninjamaster
ninjamaster's Gravatar
01/05/10 4:36 PM
Best I ever got was 200 miles before the lite came on.Put 5.4 gallons in that time.I went to 220 miles when I got fuel.The most gas I ever put in was 5.8!!!
Green means GO!!!!!!!!!!!!
2006 ZX14
2004 ZX10R
2009 ZX6R Monster
1994 ZX7
1987 Yamaha YSR50
2003 ZX6RR
1986 Ducati 750 F1A
2008 KLR 650
1993 ZX11
2011 Concours 14
2009 Aprilia RS125
extrapilot
01/06/10 4:49 AM
Maybe that -1 down on the front sprocket has something to do with poor mpg, and/or a fat maping.
Mine did not get good mpg until I had over 1K miles on the bike.
* Last updated by: extrapilot on 1/6/2010 @ 4:50 AM *
bgordon
Forum Administrator
bgordon's Gravatar
Grand Junction, CO
01/06/10 7:27 AM
I would suspect a fat map. I'm -1 on the front sprocket, and my mileage (and performance) increased from about 38 mpg to about 45 mpg with a leaner map. -bg
Sharkey
Sharkey's Gravatar
Grass Valley, CA
01/06/10 10:59 AM
It seems to me that the only way to know how far you can go, after the warning comes on, is to run till you are out of gas. I've only done that in my truck (which had 2 tanks) where I could switch over. But it really messes up your fuel injectors to run to the bottom of the tank.
When I flew airplanes in 3rd world countries, we always filtered the gas through a chamois. That gives you the best chance of getting clean fuel.
The worst thing you can do is go into a gas station when you see the big truck dumping gas into the underground tanks. You're sure to get crap in the fuel even several minutes after they are done.
I like to put about 2/3 tank full and refill before the warning. I hate walking.
Removed GPS.
