Thread: Bonneville box help
Created on: 07/13/14 06:26 PM
sdm952
Bonneville box help
07/13/14 6:26 PM
Greetings speed freaks. I recently purchased a bonneville pro from muzzys and it turns out it left the factory before it was finished. It arrived with no connectors on the harness at all. Loring speed runs are this week and I haven't had much luck with the manufacturer.
Could / would someone please be able to share a close up pic of the harness connectors so that I can get this thing wired up. Being speed limited to 186 is not the plan for loring!
Many thanks
Shawn
RE: Bonneville box help
07/13/14 10:43 PM
I have one. Not installed yet. The bullet connectors were put on by the previous owner. Hope these help. If you need more detail, I will post more pics for you late tomorrow.
There is a blue wire to the ECU that is supposed to be snipped if I recall. I have this pic saved. Better double check it was some time ago that I asked about the blue wire but I am pretty sure that is why I took the pic.
THIS IS A GEN1 ZX-14.
* Last updated by: Rook on 7/13/2014 @ 10:45 PM *
sdm952
07/14/14 5:21 AM
Thanks rook. I think that gives me enough to go by. Now just have to put the bike together :)
And off to loring....
Be well
Shawn
07/14/14 6:32 AM
Good Luck! I wish I could go with!
The white harness connectors look exactly like the ones from my SpeedoHealer that connect to the bikes speed sensor lead. They are probably the exact same connectors as those which are supposed to go on the Bonneville. You might get that part from HealTech if you can get them to ship overnight. You could order JUST the SpeedoHealer harness for the ZX-14. Try Schnitz. They told me I could buy a speedohealer harness for my Hayabusa so that I would be able to switch the SH over from my 14.
* Last updated by: Rook on 7/14/2014 @ 6:36 AM *
sdm952
07/15/14 9:04 AM
Rook if you have time some close up pics of the connectors would be awesome. I just want to be 100% sure before i wire this box up. Thanks. Hope i can help you out in the future...
07/15/14 12:05 PM
Sure hope this helps. I can't think of any other shot you would need to see but if you do, let me know.
sdm952
07/16/14 5:11 PM
Thank you. I cant begin to tell you how helpful that is!
07/16/14 9:27 PM
cool! I think I'll install mine soon. I might hit you for some pointers.
sdm952
07/20/14 5:46 PM
Just returned from loring and posted a best speed of 192mph. Bonneville box worked great. Thanks for helping with the wiring. We will head back with a couple of minor changes in september and should see 200....
07/20/14 7:10 PM
Good luck. Do a small shot of nitrous and you will have no problem doing over 200.
