Thread: Tool Kit Box
Created on: 04/30/09 08:18 AM
rcflyer1388
rcflyer1388's Gravatar
Tool Kit Box
04/30/09 8:18 AM
Has anyone modified the box under the seat and how so, mine keeps getting the cover torn off at the hinge line because of the bouncing around of the stuff inside and the not so perfect roads here in NY city
GSRON
GSRON's Gravatar
RE: Tool Kit Box
04/30/09 1:26 PM
Mine kept coming open so I did the same thing I did on the BMW GS I had before the ZX. I glued a semi-dense piece of foam to the lid so the seat base would apply some pressure and hold it closed...........
I cried because I could not wheelie. Till I met a man with no motorcycle....
Nightstalker911
Nightstalker911's Gravatar
RE: Tool Kit Box
04/30/09 4:23 PM
I took mine completly out. The empty space should give me enough room for a MINI fuse block, Alarm module and the base for my LED under bike lights.
The tool kit will be kept in my Tail Bag.
Jeff01ss
Jeff01ss's Gravatar
RE: Tool Kit Box
04/30/09 7:02 PM
when I bought mine the box was empty, so I use it for a little storage compartment.
rcflyer1388
RE: Tool Kit Box
05/01/09 12:09 AM
That's what I originally did, put a rag on top of the stuff I kept inside to keep it shut, except this time the tab stayed locked and it tore at the hinge line and everything was scattered all over the place...I usually like to keep a couple allens and a disk lock in mine in case I have a dead battery and need to pull panels...
