I need to install an accessory plug (we use to call them "cigarette lighters " ). Anyone found a good place on the bike to install and/or wire in? 2013 Zx14.
TIA
Created on: 08/25/15 12:20 PM
chrly
wfozx14
RE: Accessory Plug/outlet
08/25/15 8:27 PM
suzy1052
08/26/15 8:12 PM
I didn't want to drill out the c-f inner fairing panels, so I attached it to the underside of the headlight fairing where the windscreen joins the fairing. Had one mounted to the inner panel on a previous machine and had to screw around with the connections each time I had to get in there. This way, it stays unless the headlight fairing comes off.
You can see the dual outlet on the upper right with the radar detector and a rechargeable flashlight plugged in. The r.d. has since been moved to over the gauge pod. Everything is wired back to a terminal block that's mounted on the far side of the battery.
* Last updated by: Danno on 8/26/2015 @ 8:14 PM *
