Thread: 500mi oil change ?
Created on: 01/18/15 05:59 PM
SlowBen
SlowBen's Gravatar
500mi oil change ?
01/18/15 5:59 PM
Wanting to know if it is ok to go with synthetic oil at the 500mi service. I have been told that you have to wait tell about 2000mi or your cluch will slip. Is this true or false.
Speed is an allusion of previous experiences
2013 ZX14R AH2 with Cblast flash,yoshi fender eliminator, stompgrip tank pads, ASV levers.
RE: 500mi oil change ?
01/18/15 8:43 PM
Use kawi semi-syn brand. This way there is no question about slipping clutches if kawi has their own oil @ 600 mile first service. Page 123 of your owner's manual.
01/18/15 10:24 PM
I feel better waiting. I'd rather change oil often on a new engine anyway.
SlowBen
SlowBen's Gravatar
01/19/15 7:24 AM
Thanks for the info guys. Will be going with kawasaki oil this time. Thanks again
01/19/15 8:48 AM
If I'm not mistaken...Kawasaki fills the new motor with 300V Ester/synthetic 10-40.So yes...you can use full synthetic if you want.Motul synthetics are fine for wet clutches.7100 is a good Motul synthetic.I think I get a bit better trans shift feel with the 7100...been using it now for at least two years.Probably longer.
It can be pretty dusty here during the year...I normally will change as soon as I feel the shift action getting..."notchy'.Around 4K or so.The oil always looks like new.
* Last updated by: Grn14 on 1/19/2015 @ 8:51 AM *
SlowBen
SlowBen's Gravatar
01/19/15 10:41 AM
Grn14 thanks, I'm going to use Kaw oil this first change. At 2000mi I'm thing im going to use amsoil. I use it in all my stuff and have had really good success with it. Plus my kawasaki dealer here Carries it so its easy to get. Thanks again guys
01/19/15 10:45 AM
Yeah, I'd run motul thru that spooling, Grn. Full syn is going to slip the clutch and then sign off like the trans shifting. Semi-syn, no clutch slippage to worry about.
Full syn is thru a car engine and no clutches are in a car's engine as is a bike. So full syn and do not spin the bike up is more like a governor you slow down on the break-in. I'd look at the oil level before you take it out of the dealer.
Only click here to bust your trouser zippers open.
http://web-cars.com/images/vette_img/2015-Chevrolet-Corvette-Z06-engine-cutaway-2_a.jpg
carabuser
carabuser's Gravatar
01/19/15 1:14 PM
Slo, no hurry to go to synthetic, just change the dino oil a little more often until
you get some miles on it, just my opinion ....
Predator Race Team #14
Hayabusa
1980 GS 1100
1978 GS 550
1968 CL 350
1972 TS 90
Winston Churchill
01/19/15 7:15 PM
I've run the factory oil to say...200 miles...then changed out to 7100 full syn...the manual has this full syn listed in there...so it can't be bad for any part of the motor or clutch....just sayin.Never had any clutch slippage...not yet anyway.
jimmymac
jimmymac's Gravatar
K.C. MO Northland
01/19/15 7:32 PM
Dead dinosaurs rock!
Just like all tires these days.
You can't go wrong.
Let's roll
carinoart09
carinoart09's Gravatar
02/12/15 10:52 AM
Here's my oil filter, from my first oil change at 1 K what a bitch could not get the factory filter off, finally got it off, of course I used K & N so I can use a real wrench (yes i'm oil school kept it simple)
My old CBR 1K I ended up cracking the those plastic fasteners on the fairings.
My GOD why do they make it into a pain and the ass with sportbikes, kept it simple by using clips like the old hotrods did for the hood.
I will have to get a lift for next time getting to old and beat up for being on my back and knees....
02/12/15 12:25 PM
Mine was not so bad as yours but I also had a very hard time getting the factory installed oil filter off. I've heard that complaint from others as well. I only use OEM filters. If you turn it until it just touches the case and then ~1/2 turn more, it will not be so hard to remove.
* Last updated by: Rook on 2/12/2015 @ 12:27 PM *
02/12/15 1:57 PM
I had to gnaw my filter off with my teeth. Woof!
02/12/15 4:04 PM
I've changed my bikes oil twice now, the factory installed filter was a PAIN IN THE ASS to remove. I don't know if they over tighten it, or it just settled or something but I'm telling you I totally get hwy his oil filter looks like that.
Even the 2nd change the filter was a bitch to take off. But wasn't as bad as the original. Note in both cases I torqued the filter to spec, I think 13 ft lbs if memory serves me. I'll see how it is next year in about 3k miles (800 miles on current oil)
Rktsled
Rktsled's Gravatar
02/12/15 4:27 PM
Having trouble getting the original filter off??? It's because the assembly line crew didn't oil the rubber gasket, unfortunately it happens a LOT! I had to drive a long screwdriver thru my original filter to get it off, this is my 3rd ZX and the other two were the same way!!!
Rktsled
02/12/15 6:13 PM
That's a great old mech trick but if you need to resort to that, be sure you DO NOT pry against or hit the threads. Also use a strap wrench and turn that along with the screwdriver.
ninja191
ninja191's Gravatar
02/15/15 10:19 PM
I have noticed a couple of whacks on the oil filter with a rubber mallet or piece of wood helps to break the seal and make removal easier.
2013 BMW M5, 2006 ZX14 Passion Red, 2013 ZX14R Pearl Stardust White, 2019 Suzuki M109R
Fowvay
Fowvay's Gravatar
02/23/15 3:25 PM
Go to the autoparts store and buy a filter wrench. They're $6 and are an exact fit for the Denso manufactured Kawasaki filters with p/n 16097-0004 or 16097-0008. Buy Performance Tool W54118.
* Last updated by: Fowvay on 2/24/2015 @ 1:51 AM *
2012 ZX-14R Green
Nightmare
Nightmare's Gravatar
02/25/15 10:44 PM
Definitely pickup one of those filter wrenches as Fowvay suggested. However they won't always work, I've had a few times where the filter was stuck so bad that the filter wrench simply skips and can't loosen the filter.
I even have a strap style filter wrench that Rook was mentioning, if I remember correctly the first time I changed the oil I had to tighten it so much it crushed the filter similar to carinoart09's picture.
The service manual has some pretty high torque specs for the filter, probably doesn't need to be that tight but I figure if a bit of cursing or poking a hole in the filter "guarantees" that I won't have an oil leak, that's okay by me. :)
02/26/15 10:45 AM
"Go to the autoparts store and buy a filter wrench"...yep..been doing that now for a year or more.That wrench changes everything. The screwdriver deal can definitely get messy.Install as per Rook.No need to crank that filter down once it seats.
* Last updated by: Grn14 on 2/26/2015 @ 10:48 AM *
02/26/15 12:19 PM
https://sp.yimg.com/ib/th?id=HN.608016775154368861&pid=15.1&P=0
No offense meant, but, I'd throw that $6 towards the better tool. How better? More Universal instead. No matter the bite, this baby does the job hands down.
I've changed my bikes oil twice now, the factory installed filter was a PAIN IN THE ASS to remove. I don't know if they over tighten it, or it just settled or something...
Close. Settled for a surface tension like it's too simple to explain and as simple as it looks.
'But wasn't as bad as the original' means a metal compression or not? 'Note in both cases I torqued' as opposed to letting the oring squish to the case and now the ring of the metal filter is sort of overbiting the oring's tension alone.
It's because the assembly line crew didn't oil the rubber gasket..
Then, it's not going anywhere now! So look what we have is a dry or oiled oring and do both hold the seal either way? I'd say yes to both. Nothing that wrench can't handle.
a screwdriver thru my filter... this is my 3rd ZX and the other two were the same way!!!
Time to tool-up if you maintain your own bike. I'd buy snap-on because it's not going to wear out the pivot or slip out as fast as the junk waiting on the docks. Add the 6 bucks, the junk you almost bought and buy the best for a few bucks more. Think of it as a one time Lifetime Guarantee you walk right back on that truck and swap it out, the pivot breaks, slips, etc.
I wind mine up till I can't turn it anymore. I know that resistance is not banging case to cartridge. I do not throw 13 pounds at it, more like give it a decent grip and when my my hand spins it's torqued close enough for me. I close the oil cap filler by spinning down onto the oring and then snap my fingers off that [bar that is across the] cap. Same principal is that oring squish and that tension.
1. My cap is not squished much is the oring.
2. My cap is not metal to metal on the close.
3. My cap is going to last longer is the seal, I do not cause the compression to collapse, but has memory to spring back.
So the principal says that the compression works that well, it's not the factory, not the torque spec, but that simple design vs memory vs tension vs if someone come up with a better theory, then I am sticking to mine.
Signed,
No One Looks To Tension
ninja191
ninja191's Gravatar
02/27/15 4:48 PM
I have the wrench that HUB posted. I can "twist the whole bike upside down " with that wrench. LOL
* Last updated by: ninja191 on 2/27/2015 @ 4:49 PM *
jimmymac
jimmymac's Gravatar
K.C. MO Northland
02/27/15 5:31 PM
Most people never step foot on a Snap-on truck. For good reason.
I make a house payment every Month on tool trucks.
I take pictures of that thing every day, but this one is handy.
And unlike your penis, mine is bigger.
Let's roll
