Hi folks,
I'm kinda new to the forum, but had my 14 from new, which is now 5 years old. It's a 2009. Until last year, the bike was great, no issues..well, not apart from the horrendous clunking gearbox!! Over the last year, I've noticed I have a flat spot between 3-4k rpm...hit 4k in any gear and it takes off. I've had it into Kawasaki, they originally thought it was the petrol tank pressurising and stopping the fuel, so they stripped and cleaned the petrol cap...no change what so ever, but now when I open the tank there's no big gush of air.
I then decided to see if I could sort the problem myself...I've had bikes for years, but the last "modern" bike before the 14 was my trusty old Gpz900, which I've had 23 years, so I've not really worked on anything this new before.
That said, manual in hand, I started with the obvious...changed the spark plugs, Iridium, previously changed 3500 miles ago, so should still have had plenty life in them. Checked the stick coils, resistance within the limits on primary and secondary...pulled the fuel pump out, found this appears to be a sealed unit, so took it to Kawasaki again and they stripped it for me. Showed me the fuel filter inside it, which seemed quite dirty, so this was cleaned as there does not seem to be a replacement part you can just pop in...
Anyway, still got this flat spot between 3-4k and it's starting to drive me nuts. Anyone had anything similar and found how to cure this?
Cheers
* Last updated by: malky1400 on 9/21/2014 @ 12:22 PM *
