Didn't go into much detail making adjustments (no laptop) but i did make some changes, and the results were interesting.
You can store 10 "maps" in the sb6. You can make up to 6* advance.
I had map 1 as +1* across the board, map 2 was +2*, so on and so forth up to map 6.. Map 0 was appearantly my map from last year.. I'll explain that later.
The bike made the most power at +1*, and lost .5 hp per subsequent degree advanced.
I want to make some more passes with the software, and make actual adjustments. I think the bike will make more power with timing slightly RETARDED. This is with a thin head gasket (higher compression) and 87 octane pump gas.
My map 0 was obviously my nitrous map from last year. I'm curious to see what it is, but i'm pretty sure it's between 8-12 degrees retarded. Lol. The bike made 130 hp and 60 lb/ft of torque with that map in it.
Thought you guys might like this test. I'll post back when i try retarding the timing.
ZX-16 in 2010
8.64 at 158 on motor
8.28 at 173 on nitrous
Back to stock for 2011.
9.24 @ 148
185 hp pump gas
