After bumping up the PSI from 6 to 7, here is an observation I have made. In gears 2 and 3, 7 PSI will show near the top of the RPM range at WOT. In gears 4 and higher at WOT I have not seen 7 show up, 6 yes, but I also have not had enough non traffic open road to get to 10K in 4th as well.
For those of you all with turbos at 7 or higher, does your 7, or whatever the max value is, come on sooner in your RPM range?
What is normal to expect?
