I’ve been wrenching on these big-bore hyperbikes for years, but the moment this new 55028-0456-17P Candy Lime Green lower left cowling arrived at the shop, I had to throw it on the bench. I tore into the inner heat shielding just to compare its polymer behavior with the early OEM version—and the evolution is honestly noticeable. We all know the weak point of older OEM parts; early cowls had a tendency to soften and deform under sustained exhaust header heat, which can lead to fitment shift and that uneasy feeling of things moving around at high speed.
Running calipers over the mounting tabs, the fit is tight—cleaner and more consistent than what you typically see on earlier production runs. The material stiffness on this updated ABS blend feels more controlled, and it holds its shape better under heat soak, especially in the lower fairing zone exposed to header radiation. It doesn’t feel like it’s fighting heat as much as it’s managing it more evenly, without losing that Candy Lime Green metallic finish quality.
At sustained high-speed load, this changes how the lower section deals with heat exposure and airflow interaction. I have to ask the serious top-speed guys here: when you’re running open or lightly shielded aftermarket headers, how are you dialing in your setup to keep that heat soak from slowly pushing your lower plastics out of shape over time?
https://japan.webike.net/products/26570536.html?utm_source=forum&utm_medium=439&utm_campaign=46178
