Are Helibar the best or any other opinion? I could use about an inch or two, no more.
Created on: 09/01/26 12:59 PM
apexlocator
bmw111
RE: Helibar Risers
09/01/26 7:29 PM
I'm trying to source a superbike bar style setup from a Japanese vendor through Webike Japan. I currently have a 1" riser plate installed by the PO but prefer a bit more since I'm wanting to tour on my 2022. The Helibar risers at 3/4" wouldn't be near tall enough for me.
HanksZX
RE: Helibar Risers
09/03/26 6:22 AM
https://spieglerusa.com/controls/handlebar-riser-kits/handlebar-conversion-kit-17481.html
I've dealt with Spiegler for years...very solid company with great tech support.
I've bought numerous LSL handlebar kits from them in the past, which are no longer available.
The ABM kits are very similar and more reasonably priced since it does not include a top triple clamp.
If you don't like the contours or position of the handlebars, you can use something else.
The 1" risers can't be compared for comfort.
They also manufacture brake lines and are the only one's available where the banjo fittings can be clocked or adjusted when installing.
Hope this helps.
Hank
bmw111
RE: Helibar Risers
09/03/26 2:35 PM
That Spiegler kit is very nice but requires changing out (and the dreaded ABS flushing) the front brake lines. The stock brakes (Brembo) on my '22 work so well I don't want to affect them in any way if possible. The kit (Hurricane) I'm trying to get from Japan claims they use all stock hoses, lines, wiring. We'll see. I won't dismiss the Spiegler kit out of hand just really want to avoid changing/flushing ABS lines.
HanksZX
RE: Helibar Risers
09/03/26 3:02 PM
If the kit includes a new brake line, ask them how long it is...then measure the original one on the bike.
On my 2013, they were the same length (13" or 14" IIRC) and thus did not require changing the brake line over.
I got lucky, you might too!
bmw111
doubleD
RE: Helibar Risers
09/05/26 10:00 AM
I added 1" spacers in 2013. Gen-Mar was the Mfg, but he is gone. You can get 1" spacers off of eBay.
I do not have ABS brakes. I had to release the front brake hose bracket that bolts to the triple tree for extra play, nothing else.
Then I added 2-1" spacers per side and that made a great adjustment for me. I had to flip the throttle cables. I added a longer front brake hose. I had to get longer bolts. I got the bolts from ACE Hardware.
* Last updated by: doubleD on 9/5/2026 @ 10:15 AM *
bmw111
