Thread: Rook's Turbo FAQs and Answers
Created on: 01/08/25 06:41 AM
Rook&#x27&#x3b;s Turbo FAQs and Answers
01/08/25 6:41 AM
There’s going to be so many questions. I’m gathering information from our resident experts and Richard Peppler of RCC Turbos. I’ve already started building a FAQ list based on my own questions as I consider which system is right for me. I’ll edit in here on the OP as the list becomes more complete.
...and here it is!
Based on my conversations with RCC Turbos and a few other of you guys, here's what I came up with for Q and As.
Q: Should I go with an RCC turbo or a supercharger for my ZX-14?
A: You need a full exhaust with a supercharger, a turbo requires only a short pipe diverted out of the side of the lower fairing. Turbos benefit greatly from an intercooler because the forced induction is caused by the exhaust. The power required to generate induction by a supercharger is supplied by the engine. Even so, it appears an intercooler is used even with a supercharger, they create more heat than a turbo does. A supercharger setup will probably be heavier than a turbo too. Superchargers are often favored over turbo for low end performance but struggle with higher rpms, or are limited where a turbo excels. Superchargers introduce parasitic drag on the engine. A turbo probably restricts exhaust flow to some degree. Both produce a net gain in engine power but it seems the cost of inhibiting exhaust flow is lower than the cost of taking power directly off of the engine. The TTS Supercharger in development at the time I’m writing this is priced competitively with an RCC stage 1 or stage 2 turbo kit. The top package offered by RCC Turbos is considerably more expensive than the TTS supercharger now produced for the Hayabusa. To sum all these thoughts up, turbos are usually favored for racing applications and superchargers for street performance. …but read on because it looks like the RCC turbo measures up equally well in ZX-14 street applications to the TTS supercharger.
Q: How much lag is there with an RCC turbo on a ZX-14?
A: On a ZX-14, there is basically no lag with the Garret GT 2871R ceramic ball bearing turbo included in the RCC kits. The turbo is making 1 psi of boost at 1500 rpm, just off of idle. Target boost is achieved at 3500 rpm.
Q: Between the RCC Turbos Stage 1, Stage 2 and Stage 2 Ultra, besides the equipment included in the kits, are there differences in the turbo itself?
A: All three kits contain exactly the same turbo. If you have some other turbo you’d like to use, they can do that.
Q: Can the Stage 1 kit be upgraded to the Stage 2 Ultra?
A: Yes.
Q: Will I save money by purchasing the Stage 2 Ultra kit rather than the Stage 1 and then upgrading the Stage 1 to the Stage 2 Ultra later?
A: If the Stage 2 Ultra is what you want, you will save some money in the long run if you buy that from the start.
Q: Are all components of RCC turbo kits bolt-on?
A: All except the fuel rail which requires drilling and tapping two holes inside of the air box.
Q: Can the RCC Turbos Stage 2 Ultra kit be run without all of the engine mods required such as HD connecting rods and turbo pistons?
A: Other than secondary butterfly removal, any RCC turbo kit can run on a completely stock engine with the 4 to 6 psi waste gate spring. A thicker head gasket, high performance head studs and valve springs and mods to improve oiling are the first engine build steps for higher boost.
Q: Will it be necessary to alter any ECU parameters such as timing or rev limiter to run the turbo safely?
A: RCC offers a specific flash for the ZX-14 that alters the ignition timing and sets up an over rev safety factor. Typically we raise the limiter a bit, depending on how the engine is built or not built.
Q: Is it possible to edit the RCC flash using Woolich software?
A: You can but there is probably no reason you would want to do that, the RCC flash was created specifically to work reliably and safely with the RCC turbo setup. If you have reasons to adjust any parameters of the RCC flash, that is possible using Woolich software.
Q: Does the RCC flash adjust fueling requirements of the RCC turbo?
A: The RCC flash does not address fueling needs. A Power Commander 5 with PTI seems to work perfectly for the Stage 1 kit. The Stage 2 kit includes a secondary ECU that will monitor boost pressure and adjust fueling as required. If it’s necessary to adjust fueling for reasons other than boost pressure, you would need to use a closed loop tuning system and a standalone ECU such as Maxx ECU or use Woolich software and related equipment to adjust your own custom mapping.
Tuning for turbo is something I still have lots of questions about. I’ll update this info as soon as I learn more. For now, it looks like the RCC flash with secondary ECU or the PC5 with PTI are both excellent and easy to use options.
Q: Are carbon fiber wheels safe to use with your turbo?
A: There have been problems with carbon fiber wheels cracking. If you use them, it’s probably wise to go with one that’s designed for use with turbo.
Q: What is the weight of the Stage 2 Ultra kit and the intercooler?
A: The shipping weight is 50 lbs or slightly less. The parts removed to install the kit weigh at least 40 lbs.
Q: If I prefer the look of separate exhaust and dump pipes to the single exit of the RCC turbo, can I have that?
A: The combined waste gate and exhaust pipe exit designed for the RCC kit requires no fairing trimming but the RCC pipe can be removed from the exhaust port and the blowoff valve. Separate exhaust and waste gate pipes, could be fabricated. The RH lower fairing would also need to be trimmed to fit separate pipes.
Q: I also prefer the look of the air filter sticking out of the LH fairing. Is this possible with the RCC kit?
A: The RCC kit was designed to minimize the visibility of the turbo but a longer filter may be used provided it fits the diameter of the turbo intake port. You also may need to trim the LH lower a bit differently to fit a filter other than the one that comes with the RCC kit.
Q: Can an aftermarket exhaust with muffler be used with an RCC turbo?
A: Aftermarket exhausts are typically too small and restrictive, RCC Turbos offers exhaust options including one with a carbon fiber can muffler with slash cut exit. They also have a shorty shaped somewhat like an M-4 Retrodrag muffler. Both appear to be larger in diameter than typical aftermarket exhausts.
Q: The intercooler that comes with the Stage 2 Ultra kit has a heat exchanger that is positioned in front of the radiator. Doesn’t this block airflow to the radiator and create extra heat that impacts the effectiveness of the engine cooling system?
A: The heat exchanger is only trading heat when the turbo is generating higher boost. This is at higher speeds. Low speed and normal street riding engine temperature isn’t effected by the heat exchanger.
Q: Is there an advantage to using water/meth injection along with your intercooler?
A: No, not really. [I’ll be looking more into water/meth injection in the future. From what I’ve heard, it not only reduces engine temperature but it might even produce more power].
Q: Is oil leaking from the turbo when the bike’s shut down something I'll have to live with?
A: The ZX14 kits we sell come with a 1 psi check valve so no oil leaks past it on the feed line when the engine is shut off, and we use a mechanical scavenge pump so no oil back up from the drain side either
* Last updated by: Rook on 3/22/2025 @ 4:13 AM *
RE&#x3a&#x3b; Rook&#x27&#x3b;s Turbo FAQs and Answers
01/08/25 6:41 AM
First questions:
1. Should go directly to the RCC Stage 2 Ultra or start off with a Stage 1 and upgrade?
2. Assuming I go straight to the Stage 2 Ultra, can I safely run it on low boost until I have completed the necessary engine mods to run it at full power?
3. Can I install the entire turbo system myself and do all the engine mods necessary to run it? …or is this something only a professional mechanic should do?
* Last updated by: Rook on 1/8/2025 @ 6:42 AM *
RE: Rook's Turbo FAQs and Answers
01/08/25 11:04 PM
Ask the guy selling the turbo if it is a bolt on kit, no machine work needed?
Difference between stage 1 and 2 is what?
I'd go stage 2 being it runs normal until spooled up. Can use base gaskets for lower pressure (if applies), 2 head gaskets I doubt, or if someone makes a thicker copper race kind of gasket.
You'd have to run a low comp piston if the stage 2 requires it. Pulling the engine and splitting the cases should not be a problem for your aptitude, Rook.
Kit wise is seeing some turbo hardware to mount that puppy on. So no machining to be done, or buying spare flat steel plate for turbo hanging frame/engine supports.
01/09/25 6:57 AM
I'm sure the RCC turbo itself is straight bolt on just like a header. It's made for the ZX-14 so it must fit right up. I wouldn't be surprise if it would be necessary to do some drilling and tapping threads for oil lines and maybe fab up some light retainer brackets. I will ask him about the need for machining though.
There are three levels of RCC turbos, Stage 1, Stage 2 and Stage 2 Ultra. All use the identical Garret GT 2871R ceramic ball bearing turbo. Looking at the three kits, it appears there are differences in parts and electronics included with each but many look the same between all three. The Stage 2 Ultra comes with an intercooler. Looks like they each make up to 440 hp with the proper engine build and race gas. All make 260 to 280 hp on a stock engine. YES, you can run it on a stock engine! Low boost.
Thanks for the vote of confidence Hub. I might have a go at this. Nastynotch said he thinks I can do it too. Turbo pistons and HD connecting rods are required for higher levels of boost.
The intercooler with the Stage 2 Ultra grabs me. As far as spooling, Richard from RCC Turbos said the ZX-14 has virtually no lag. The engine starts making 1 psi of boost at 1500 rpm and rises to target boost at 3500 rpm. The Hayabusa does have a little lag with the RCC turbo.
Have a look for yourself, Hub. There's all kinds of interesting junk that comes with each kit.
* Last updated by: Rook on 1/9/2025 @ 7:00 AM *
01/10/25 11:32 AM
Gulp, that is a lot of Benji's. Carillo rods for sure. Have to plastiguage the crank rods or tool up and have inside/outside mic's to measure. Very critical there. Insurance for sure are the rods being changed no matter the boost. Just saying even the stage1 is how I'd approach it.
01/10/25 6:52 PM
I'd only be splitting the case once if at all possible. The rods and pistons would get changed along with anything else in there that needed to be addressed. I seem to recall Romans speaking of running turbo on a completely stock engine. He was increasing the boost incrementally but never found the point where it blew up. The integrity of the engine must have outlasted his nerve.
01/10/25 11:10 PM
Hub, from my emails with Richaard Peppeler:
OK, maybe a silly question but since we're on the topic of required engine mods, could the Stage 2 Ultra setup be run on low boost using only the equipment included in the kit? ...and I'm sure some kind of fuel management system or a flash.
...in other words, RCC turbo on completely stock engine internals.
Richard Peppler
Wed, Jan 8, 6:16?PM (3 days ago)
Absolutely.
Richard Peppler
Thu, Jan 9, 7:27?AM (2 days ago)
to me
The secondary ecu included with the stage 2 will look after the tuning, just leave the 4 or 6 psi waste gate spring in the gate and you will be fine on a stock engine, waste gate spring is dependent on the year of your bike,
So hub, the Stage 2 RCC turbo is a pretty expensive aftermarket exhaust but it doesn't just release a few hp, it actually creates hp! I'd want to build the engine to get all the turbo has to offer but until that time....260~280m rwhp...? That might be within reach with no engine mods. Like a nitrous kit but you never need to worry about the bottles going low.
Fordtech is bringing up the matter of available fuel management for such a new bike though. It' a bit of a challenge to get OEM parts for a 2024 let alone aftermarket stuff that interfaces with the ECU. I still have a wrecked 2008 though, don't I.
01/12/25 12:37 PM
In ongoing conversations with Richard Peppler, he explained that the Stage 2 kit includes a secondary ECU that monitors boost pressure and adjusts fueling. I don't know if "plug and play" is quite the right idiom but ...."lots of hours of work and play" might be perfectly accurate. ...anyway, looks like the kit is designed to run on the bike with all the loose ends tied up.
01/14/25 6:27 AM
To the question of machining, there is no need as far I'm aware right now. The air box needs to be drilled and tapped to fit a fuel rail. Fordtech58 mentioned dropping the engine to do this (so you can fit the drill under there I assume). RCC instructions say to drill from inside the air box. Seems you'd need a very small drill or else a very long bit. Either way, hope to heck the holes exit in exactly the right place under the air box so the fuel rail mounts match up. I can see why a person might choose to drop the engine just to drill these holes into the air box rather than try drilling from the other side and hoping they match up. I might pay a machine shop to do this. You F up the airbox, you buy a whole new frame to replace it.
If there's any other safe way to mount this fuel rail, I'd try it before drilling the air box on a new bike.
* Last updated by: Rook on 1/14/2025 @ 6:29 AM *
01/15/25 6:25 AM
Fordtech58, Romans, you think a person could fab out some tabs to mount the fuel rail and have them welded to the underside of the air box instead of drilling and hoping for the best? Weld tabs and maybe not need to drop the engine. Screw up the positioning, no big deal to grind the tabs off and try again. Screw up drilling through the air box and you are really screwed.
* Last updated by: Rook on 1/15/2025 @ 6:26 AM *
Fordtech58
Fordtech58's Gravatar
01/15/25 10:15 AM
Rook I think you're over thinking it as I don't believe it'll be a problem. I reviewed the printed copy I have of the stage 2 instructions. You DON'T have to lower the engine, you use the new fuel rail to mark the 2 locations to be drilled. You drill the 2 holes with a 90 degree drill and a short bit. One hole goes between the 1-2 throttle bodies and 1 between the 3-4 throttle bodies. IF you happened to miss the alignment you're drilling a 6mm hole which could easily be sealed with a 2 part epoxy that you're already using to plug factory holes near the steering stem. I'll make another attempt to get you the instructions by the weekend.
01/16/25 7:16 AM
Thanks, Fordtech58. I'm not so sure a slightly misaligned hole would be a small problem. If you're off by only a couple milimeters, then you need to drill in almost exactly the same spot you just filled with epoxy. Maybe it will seem a lot less daunting once I see what I'm working with.
OZrevhead
OZrevhead's Gravatar
Sydney, Australia
01/25/25 10:38 PM
Hey rook, can you send me the installation instruction for the stage 2?
Cheers
OLD GIRL - 2007 Black zx14, Muzzy 4:1, PCV, QS, 1" risers, 165hp so far @ 142,000km, 9.66@144.6 ....... NEW BABY - 2014 Green/Black ZX14R, Two Bros slip-ons, PCV, Dynojet QS, 1" risers, Sargent seat, Brocks clutch kit, 206 HP on dyno
01/26/25 4:21 AM
.......well sure. I will send that along directly, OZ. Takes about 25 minutes to read and understand if you know the ZX-14 as obviously you do. No intercooler instructions. I sent an email to RCC asking to see that.
I'm sure I'm going to go ahead with this. The only issue at this point is money and that's not an issue for me I'm happy to say. Not too many times in my life has money not been an issue.
...the other issue I'm grappling with is cutting and drilling on a brand new friggin bike. I mean, money is not an issue but it sure isn't growing on a tree I'm picking it off of. I'd rather do this to a bike 5 years old or more.
01/26/25 4:27 AM
OZ, we were communicating by PM here on the forum. PM me your email so I can send that file.
OZrevhead
Sydney, Australia
01/26/25 5:30 PM
PM sent
01/26/25 9:34 PM
emails sent. Let me know if there's any problem with the files I sent you. I put the intercooler instructions in there too. Just got that a day ago. Looks awesome! Kind of a weird place for the heat exchanger, right in front of the radiator..... ? I'll have to ask Richard about that. Must work ok but seems you're sacrificing some engine cooling to gain intake cooling....
* Last updated by: Rook on 1/26/2025 @ 9:40 PM *
01/27/25 1:48 PM
Far positioning the intercooler heat exchanger in front of the radiator, Richard said there is no noticeable difference in engine temps. The heat exchanger is only trading heat when the bike is operating at higher speeds, there isn't much boost happening in normal street riding.
I actually wasn't even thinking about the heat the heat exchanger might give off, my concern was that the heat exchanger seems like it would reduce the airflow to the top front surface of the radiator. I'm taking Richard's word that the heat exchanger has no effect on engine coolant temperature. He's been developing this product for years.
* Last updated by: Rook on 1/29/2025 @ 6:25 AM *
01/30/25 4:09 PM
A bit of a surprise but you're going to add weight by going with an intercooled turbo. The whole kit weighs 50 lbs and the stock exhaust should be about 40 lbs. Also, RCC turbo isn't giving the green light on CF wheels. He's experienced CF wheel cracking after just a few passes on his Prostreet bike and I assume that was drag racing. Lots of stress on those wheels, massive torque in back and wheelies up front. I'm crossing carbon wheels off the mod list for this bike. I think a set of white OEM wheels or maybe aluminum but not CF.
Fordtech58
01/31/25 11:38 AM
I've been using them for 3 years now 6.75" rear with a slick. 1.261 best 60ft. granted I'm currently only about 300hp a lot less than a prostreet bike but also a lot heavier. The fault in my opinion is usually the choice of BST wheel. The 7 spoke is the ONLY one listed by BST as acceptable for drag racing. That was 3 years ago now, not sure what they list or suggest now as they have developed at least one new design.
01/31/25 10:44 PM
Thanks Fordtech. I'll have plenty of time to mull that one over. I don't see making any high ticket purchases for this bike for a while after I buy the turbo kit.
02/14/25 4:03 PM
RCC Turbos offers ECU flashing according to the engine build (or without build) of your ZX-14. The fueling is taken care of with the secondary ECU that comes with the Stage 2 kit. For this reason, there are no fueling adjustments included in the RCC flash. The turbo runs on stock AFR numbers plus the MAP sensor included with the secondary ECU.
Would there be reasons a person would want to control the fueling and AFR numbers if they were relying on the secondary ECU and the flash? ....changes in ambient temp, altitude, humidity....the normal test and tune tweaks?
* Last updated by: Rook on 2/14/2025 @ 4:03 PM *
Fort Worth, Texas
03/19/25 11:57 AM
What are you thinking about doing now? DIY Install? I know a shop in Houston called Boomstune HQ does a full install, dyno tune, engine upgrades, and turbo for about 10 grand drive in, drive out.
03/20/25 8:39 AM
Thanks for the suggestion but yep, and I'm about done thinking about. There's no reason I can't do it and I'd rather do all the work myself, anyway. It's gonna be a long project but I like that. The turbo kit is tried and true, can be run on a stock engine at lower boost and still get some impressive hp increases. As for basic engine upgrades, I can do that but that will come a little later. Major upgrades at some point too.
I live in Upper Michigan so it actually would be feasible to bring the bike to RCC Turbos in Canada and let Richard do it. There's also one guy here I might trust to do the work for me...but why let someone else have all the fun? The turbo kit itself is ten grand but we're talking fuel management system, intercooler and most importantly, I have complete faith in it.
03/20/25 8:39 AM
danmin. I see you're new here.
