Thread: 2013 Fairing removal (im new)
Created on: 10/18/15 01:13 AM
Maddy
Maddy's Gravatar
10/18/15 1:13 AM
Hi Guys, im new to the 2013 zx14r, I upgraded, but still have my zx9r.
Can someone point me to a youtube clip or something to show me how to safely remove my fairing ?
Thank you
Maddy
Gosford NSW
2013 zx14r se Metallic Spark Black/Golden Blazed Green, Woolich Racing ECU Flashed, Woolich quick shifter, well sprung suspension set up, Givi pannier bags , bar risers , touring bubble and a top box for my handbag.
yannih
yannih's Gravatar
Queenstown New Zealand
RE: 2013 Fairing removal (im new)
10/18/15 2:48 AM
Gday Maddy,
2012 ZX-14R removing body work..
Courteousy of Smokinzx14.
See you at Pie or Road Warriors sometime!
* Last updated by: yannih on 10/18/2015 @ 2:52 AM *
Maddy
Maddy's Gravatar
10/18/15 3:01 AM
Thank you yannih
My partner and I ride to and fro sydney a bit, she has a ninja 1000.
Sing out if you see us, we also ride our nines at times.
toledoUPSguy
toledoUPSguy's Gravatar
10/18/15 12:42 PM
Lee's is good but this one is even better
Alien head 2 installation
* Last updated by: toledoUPSguy on 10/18/2015 @ 12:46 PM *
untamed
untamed's Gravatar
10/19/15 8:43 AM
Brock's video helped me plenty. Just don't force anything. Go gently. Don't over tighten when you put panels back. Especially where the tank cover fastens above the grills on the back end just below the tank. Those screws are in a rubber "grommet" that is in the wall of the frame/air box. They are easily damaged if you tighten it too much and will pull out.
AussieZX
AussieZX's Gravatar
Sydney, Australia
11/09/15 1:40 AM
Maddy, I used the one yannih has recommended. Does the job.
2013 Kawasaki ZX14R in green thanks!! In my part time, I take photographs... www.alluringlightimages.com.au
Scorpion Exhaust
Bar Risers
Double Bubble
Pussy Grips
Kawasaki ZX14R Blaze Green
Kawasaki ZX14R Midnight Saphire Blue
Honda CB500X
11/10/15 9:03 AM
ROOK has a good tutorial about bodywork removal in this site. I believe it is a sticky even.
11/10/15 6:09 PM
..unfortunately, it only covers the Gen1 fairings. I'd love to do a 14r fairing tutorial but one of you will have to donate your 14r to ME first!
Blkcasper
Blkcasper's Gravatar
12/21/15 11:48 AM
Well I've had my plastics off quite a bit between the 2 Zx14's I have had 2012 and 2013. should do a write up next time I take them off. here is what I do. You can follow above videos but there is some extra steps that don't need to be done. The left and right side top and lower can be removed as one piece. Gen2 only..
1. Remove foremen grills,
2. remove ram air covers.
3. Remove tank cover.
3. The Left and right side top and lowers can removed as on piece. To do this remove all push tabs under front nose
section, remove screw on top side under the ram air tubes, remove, tank cover plastic, remove push tab in center of front lower, remove all bolts on bottom lowers. Unplug signal lights, remove left side as one piece, remove right side top and lower as one piece. when I get time i'll post pictures.
Luvin My ZX14R'S.
12/25/24 3:00 PM
Just doing some searching here after the fact. Probably the first fairing you'll remove will be the grills. You'll bust off that front tab if it isn't cleared from the inner rubber cover. Watch for a future tutorial by me. I know it's 12 years after the bike was made but time there be some real clear instruction on this.
