2006 ZX 14 @ 9,000 MI.
Its been 4 yrs and 22,xxx miles since i adjusted clearance. First bike that i have done major maint on.
At he time i was on another Forum and ref here and i used The ROOK formula. My bike wasnt starting easily cold. Again , only less than 9,000 mi ODM. After disassembling and getting involved in the valve clearance adj. I came up with the idea that i could extend the next recommended Valve job by taking extra steps now..
Is this a thing or was i over thinking it?
So instead of just settling for each valve being in tolerance @ the time. I used Rooks formula, whatever each clearance was,, i subtracted that from the max allowed, then added that measurement to the shim that came out of that position, then replaced each shim so it was at the max allowable clearance, INTAKE - EXHAUST.. also hoping i can get a longer interval to next next job..
Does this make since, or no - go?
Presently i am about 4-6000 till due again, with no signs of needing adjustment.
I understand that some will try for min clearance for more power. So i felt i could extend the life by doing the opposite. Although there isnt much diff from min to max allowable.
Basically replaced or moved every shim...
@ only 9,000 miles, 3-4 valves were below min allowed tolerance and others were close...
During my explanation here, i might have got the terminology switched around, but i think you should understand what i was thinking.
Its been awhile since i did that...
