Except that they need to be "constantly adjusted"....apparently I got a decent one?
AN EFFECTIVE SOLUTION
"To eliminate this problem we installed an APE manual cam chain tensioner in place of the factory automatic one. Using basic tools, the installation was completed in around 20 minutes and immediately resolved our loose cam chain issue. We have been testing at the track and out on the streets for well over a month with the tensioner installed and we have had no issues and it has required no adjustments. The motor consistently sounds nice and tight with zero cam chain noise."Found on an R1 forum.
My experience as well.I am however thinking about maybe fashioning the stock one into a spring loaded one.It seems that by removing the inner parts,threading an adjuster bolt through the body,and cutting the spring and reusing it along with the piston it could work quite well and still allow some chain movement without excess.Anyone have any thoughts on this idea?It would eliminate the real possibility of the factory unit failing,and still not restrict the cam chain from flexing during the tight part of the run?This deal with the chain slack....one side being "tight",the other having slack...that doesn't make sense to me...that it would be doing this while running.I mean,once she starts rolling,won't any slack continuously move around the chain run...not just stay "tight" at one point or the other?
This is my understanding of it.The adjuster is at the rear run.Basically,that run is virtually the same length as the front run.It can't slap at the top.The shoes are up there.Nor would it slap at the bottom,as it's crossing the lower sprocket there.So they push the chain in at the rear run.Adjusting the slack via the rear run with the motor running keeps the tension constant pretty much throughout the whole run(as the factory tensioner does once the oil pressure's up).That's why I don't see how determining the "tight" part,and rotating it to the tensioner part,then adjusting makes any sense to me.Why would the chain be tight ONLY one point?This whole thing of determining the tight part and rotating it to the adjuster point...I don't get this at all.If the gears and such are equal and undamaged,then how would the chain have a chance to develope a tight spot?Seriously...I'd like to understand this.I'm not trying to say it doesn't or can't happen.I only want to know HOW it could happen.I could see it if the sprockets were beginning to wear...yes...having areas of slack everytime the chain passes over that spot on the gear.That wouldn't create MORE tightness.It would create MORE slack.But how is the manual tensioner any different than the hydraulic one in regards to applying pressure on the slack part of the chain as it comes around to the rear run?It's adjusted to the point of taking up just enough slack to stop the slapping.Be it front or back of the run,and how could it be tighter at the front...this I'm not getting
.Unless the manual one was adjusted TOO much against the shoe,I can't see how any abnormal gear wear would occur.And if she started making noise again,a small readjustment would be all that was needed to compensate for normal gear wear,which probably would mean MANY miles in between
I could see however if the factory one failed,a serious slack problem which could possibly cause a gear /tooth jump.
Well...okay...I reinstalled my modified stock tensioner.Put er in there preadjusted to the same length of the manual one...had to cut the spring down a couple of rungs to match the manual setting.Started my baby.Got a consistent rattle(but not real bad)on startup and idling(probably from it being spring loaded now instead of static load from the manual bolt).Adjusted the bolt till she was quiet(didn't take but a couple of turns to get it quiet.. so the spring still has plenty of action still available).All done now.So I've turned it 180 out so the oil passage will be blocked by the tensioner body.The tension is now variable as the chain runs through the circle.It can give and take without having a set force at every tight or slack spot there may be,or will be.The stock spring is allowing the shoe to move against the chain as it needs to.I can't see why this will not work alright.
* Last updated by: blue07 on 8/22/2010 @ 5:03 AM *
