The ZX14 as far as I can tell has no Accessory plugs.
So I did up my own.
Fuse Block is a Blue Sea 5025.
Currently have connected two 12 Volt Marinco 12V receptacles.
A 30 amp Vehicle relay. Green Wire sleeving really adds to the look.
Plan on using it to charge my Cell phone, MP3 and GPS. Plus plenty of room to wire for heated grips and vest.
Here is the layout if you can see the numbers.
1) Goes to The Positive Batter Connection.
2) Inline Fuse in case something goes wrong.
3) Relay, which is connected to the rear tail light for powering up the Fuse Box.
4) The wire running to the rear tail light.
5) Positive connection for the Fuse Box.
6) 12 volt cigarette adapter. Currently sitting in the under seat tool box.
7) Ground connection, one wire runs to the battery ground, other goes to the relay.
* Last updated by: bgordon on 4/21/2009 @ 8:12 AM *
'08 C14
'07 V2K Classic
