Basically as the title says. This has been an intermittent issue on my 2006 14 since sometime last August but could have been from even before I purchased her in July. The temps over here have been high the past few weeks so it's drawn attention to itself once more. The basic gist of the issue is when it's hot out, high 70s and up, my bike will bog / stutter / jerk / surge / hesitate sometimes. Bog in this case means that the bike lurches forwards, akin to engine braking but more aggressive, before picking back up in a few moments, often times repeating until backing off the throttle slightly. Any ideas what it could be? I've done some narrowing down of factors and have basically gotten all the easy ones. From here on out it's going to either involve a lot of labor or new parts, so any ideas or pointers would be greatly appreciated. I'd also like to apologize in advance for this rambling post, there's a lot of info to dump and I've got a lot of thoughts.
Examples of the issue: A couple days ago I was at a stoplight turning onto a long, straight country road in 78F weather. Light turns green, I get on the throttle a bit more than usual to try and have some fun. Once I hit around 6 or 7k rpms in 2nd gear the bog popped up quite aggressively, keeping me around 50 mph for about 10 seconds before I could add power without triggering it again. Prior to that stoplight, I hadn't had any issues on the ride. I've noticed a few other times where it manifests after moving in slow traffic or stoplights when heat has been allowed to build up without wind to pull it away. It doesn't always occur when accelerating. I had it happen when I was cruising at 80 on the freeway in 80F, sunny weather. After 30-40 minutes of riding, the bike began to bog and surge a few times every 5 to 10 minutes, sometimes the bog/surge would occur a few times a second but sometimes it would be longer, slower heaves and hos.
Other factors that seem to affect it: If the bike is having her fit and I crank the throttle more to try and remedy it, the bog and surge get more violent. The engine brake effect is stronger and lasts longer and then the subsequent surge will throw you back in your seat. I had it happen last night and it occurred when I flipped my high beams on, not allowing me to apply hardly any throttle without causing the bike to jerk and stutter. The second I turned my brights off, the bike went back to behaving nicely.
My thoughts: The bog and surge tells me that the engine is for some reason or another, missing combustion. Because it occurs exclusively in hot weather and even more so when the bike is extra hot from not moving fast, I'm thinking that it is either a fueling or electrical issue. I'm specifically thinking that maybe the fuel pump loses strength when it gets hot, or there's some way that the sparkplugs aren't going off. I'm nowhere close to a mechanic so these may be completely implausible, but it seems to make logical sense to me. It also seems like these problems could be caused by a faulty ground, but I've no clue how to go about diagnosing that.
What I've done to cross off possibilities:
• I have run about 3 cans of seafoam and a bottle of Chevron injector cleaner thru her over the past few months, I also try to run exclusively Shell V-Power Nitro+ 93 octane gas, so I'm fairly certain it's not an issue with injectors or fuel lines.
•I pulled the tank off and took apart the fuel pump assembly last fall. No rust was visible in the tank, although the fuel pump pickup sock filter was a little dirty. I let the sock sit in seafoam for 15 minutes before reinstalling. I also stored her with a full tank of ethanol-free gas over the winter. So, it's unlikely it's a clogged fuel pump.
•I've ridden with the fuel filler cap opened slightly and it still happened, so it isn't an issue with a vacuum forming in the tank.
•The engine never throws a code when it happens. Looking through the maintenance manual, there seem to be distinct error codes for issues with the FI system. Because none of those have popped up, I'm inclined to think the FI system isn't to blame.
•The onboard voltmeter usually rests between 14.2v and 13.8v but will drop to 13.6v if it's extra hot out and I've been stationary for more than 2 minutes or so. This is still within acceptable operational voltages, so I don't believe the charging system to is to blame.
•I checked the air filter and it is quite clean, so the engine isn't being starved of oxygen.
•I took her to a Kawasaki-authorized shop to have it looked over and the valve check done when I bought her. They said they were surprised with how good the inspection looked. This was last August so it's possible that it's an issue that has gotten worse since then, or it is something that wouldn't normally be caught by a standard shakedown.
A curveball: Back during fall of last year I had two occasions where all of my gauge-cluster lights illuminated and my headlights were super dim, much like the issue found in the old thread https://zx14ninjaforum.com/messages.cfm?threadid=6E21A180-CC7D-7075-658AE12DEFD4C09E . It only happened twice and hasn't happened since. Over winter I took off the intake cover and found that the connector had already been replaced by a previous owner with a waterproof wire nut. I rewrapped the whole thing with white electrical tape and just earlier today I took a look and saw a small mark on the white tape that looked like a burn. It's noticeably harder/stiffer than the surrounding tape and doesn't rub off, even with a little moisture. Possible that that's the faulty ground? My only concern with that explanation is why do all the front lights work as normal when they should be malfunctioning if the ground connection is sloppy.
In summary: Bike bogs when it's particularly hot out and the bike is also hot. Currently thinking it's an issue with electrical connections causing either weak fuel pump or insufficient power to fire sparkplugs. Would like to hear any ideas or pointers on things I might've missed or things to do to diagnose or fix the problem. I'll add to this thread when I figure out new things or test hypotheses. Thank you for your help in advance.
* Last updated by: Kozuki on 6/16/2025 @ 8:15 PM *
