Just discovered my valve cover leaking........ Coming down slowly around cylinders 1 and 2 and collects on the header stud and drips from there. Maybe parking on the side stand allows it to collect there?All the symptoms.
......will be putting my washers in tonight. Not too big a deal.
Also have had the cam chain making noise the last 3 months.
Prolly just your imagination working on you. Change oil and I'm sure it will get a lot better. If it is at all related, it is because your oil level is lower from leaking or it is just suffering from thermal breakdown assoc with normal use.
I remember the cam chain noise didn't show up the very first time I started it with the synthetic in it (I was listening for ANY change) but it did start about 3 rides to work (20 miles round trip) later
Ya, that expensive synthetic is nice and smooth ainna? for about 500 miles. then it's normal oil. Go with cheap and change more frequently is a good approach IMHO. I used Rotella Synthetic the last time. Same price as Kawi conventional oil. Can't say if it is any better than Kawi or the $80 worth of Repsol 4T I put in it a couple yaers ago.
I saw some misting on my fairing and couldn't see anything obvious so I wiped it off and blamed it on the road. So that first sign would narrow it down to 10/11 weeks since the change to syn'.......So I'm going to try changing back to the Motul and see if it effects the cam chain noise and the leak.
Seems like all our bikes react a little differently to changes.Actually seems like you and I have the same story. I think all the bike react the same its just the owners that percieve things differently.
I've heard that synthetic can/will leak through easier than conventional oil. I've read it many times so some of it is true.
I hope changing back will at least slow down any leaking so I can wait to do the 15K valve check. Get to throw out $55 in oil after just 400 miles.
Perfect timing. Those head cover bolts are coming out anyway. time to shim them. I don't know if changing the bolt gaskets would help or maybe even solve the problem. Seems like everyone reuses those. I did. I'm trying the washer trick and will go with new top gaskets next valve check.
I never had much of a leak. I could start at upper oil level line, do a 400 mile trip and still not drop lower than the lower line. I added about 1/4 quart/500 miles.......allowed me to use up all of that 5th quart we buy to get the level right at center.
toss that old crap out. Be glad you didn't get something too fancy, I guess.
QUESTION: I'd like to keep the oil filter. The SM says if I don't change the filter there will be about .4 qt of oil still in the filter area. Do you think this much synthetic mixed with the dino oil will compromise my oil change..."experiment"? Thanks for any help.NO, not any more than my adding 1/2 quart of conventional to the Rotela has improved my situation. Still leaks like a sieve. ---well not that bad, but it leaks.
The Rotella was the first synthetic I used in ~25,000 miles. Did not seem to seep any worse than the Kawi 10/40 I was using. Pretty sure the Rotella T6 5/40 is a lighter weight oil than 10/40 too.
* Last updated by: Rook on 11/27/2011 @ 12:06 PM *
